Question about Maytag Atlantis MAV8551 Top Load Washer
Turn on cold wash and no water will run.
The hot water will run but no cold. I unhooked the cold line and turned on valve and cold water ran out of line so i have water there. when i hooked it back up the cold water started to run , so i turned off washer and moved back into place. then when i turned on cold wash no water
  • 370 Answers
It sounds like your cold water celenoid is going out. You have to replace the whole water valve. it should be around 30 bucks. your local parts store should have it in stock, Just take your model # with you.
Posted on Nov 21, 2008
Need to remove and replace electronic water valve
First off unplug washer.
Turn water off hot and cold.
Disconnect water lines from valve.
Remove screws from top panel on washer then slide top panel off.
Remove connections on valve. Make mental note for what goes where. ;)
Remove valve.
Install new valve.
Connect wires.
Put panel back on and screws back in.
Connect water lines hot for hot and cold for cold.
Turn water on and check for leaks around connections.
Plug washer in.
Run a load!
Hope this helps.
Oct 26, 2012 | GE WBVH6240F Front Load Washer
Cold water doesn't run into washer on any part of the wash/rinse cycle. Checked cold water line but not plugged uphecked back of washer where water line connects and no clog there either. Makes a...
Sounds like the valve isn't working properly.
One way to test is to turn off the water supplies and at the back of the machine switch the hoses.
Turn on the water and see if you get cold and not hot . If so replace the valve assembly
Jan 23, 2011 | Maytag Washing Machines
Amana Model LWABOAW Manufacturer # PLWABOAW Age: Approximately 12 years. Ran fine up to now. This morning the machine would not run using Cold/Cold setting. If the Warm/Warm, Warm/Cold or Hot/Cold...
Hi
I believe the issue is with the water inlet valve assembly going bad and should be replaced, this unit has two valve one for cold and another for hot. You can test the valve first if that is fine then check the pressure switch which is part#4 in this diagram. Hope this helps...please post back for further assistance.
Daniel
Jan 19, 2011 | Amana Washing Machines
No hot water going in
your water inlet valve is probably bad or stopped up with debris. some valves have screens that can be cleaned. you can swap the cold line and the hot line and check it that way. (you should get hot water when set on cold this way and cold for hot) be sure to turn the water off before swapping the hoses or you may get a little wet.
if the valve needs replacing you will need to remove the cabinet from the machine.
May 25, 2010 | Kenmore 24872 Top Load Washer
Check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
May 17, 2009 | Electrolux EW1000i Front Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Cold water line
replace water valve and fill hoses
Mar 21, 2007 | Whirlpool LTE5243D Top Load Stacked...
Maytag Atlantis MAV8551 Top Load Washer Logo
105 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
