Question about Toshiba Satellite A100-S8111TD Notebook
Wireless network undetected and problem with wireless lan
Hello sir
I got toshiba laptop with amd processor and iam unable to connect to internet through wireless .It cannot detect any wireless device though it is on frm the front it says cannot detect any wirless or it says wirelss lan is disabled .So wat should i need to do the other ways to detect the wireless network and connect to the network.Can you please help me out to come out of this problem
  • Zarcc May 11, 2010
    I guess I'm a sir so I have to answer, eh?
    Alright, what OS are you running?
  • 55 Answers
First check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
Posted on Nov 22, 2008
Lifebook P Series Fijitsu, Model Nuber PH520. Even though there are wireless internet connections available shown on other computers, the Fijitsu cannot find any wireless networks. There are not wireless...
Did you turn off your wireless antenna by accident? The on-off switch for Wireless LAN is located on your computer's right hand side - if that's turned off, both wireless and bluetooth will cease to detect any signals or connections.
Sep 13, 2011 | Fujitsu LIFEBOOK PH520 Ultra Portable...
Iam unable to connect through a wireless to internet connection,,However if a plug cable and could connect though LAN. my ISP is BSNL and modem WA1003A ,, I tried through 192.168.1.1 by checking wireless...
>Try this steps sir, but please don't give me a low rating if this doesn't work.. :'(
>Check your computer's wireless capability
>First, make sure there is a blue light on the wireless indicator on your laptop
>If it's not lit look for the wireless switch somewhere on the computer's sides
>Now that the wireless light is lit press Fn+F5 to enable wireless capability
>try to detect wireless networks
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | Computers & Internet
Lan connection not working on Toshiba satellite laptop
Try setting up a new Broadband internet connection. Input all the appropriate Login info and you ought to be good to go via the LAN port. Everything else is aimed towards Wireless.
Sep 19, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba NB 205 connects to router but not internet
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
Aug 17, 2009 | Toshiba Computers & Internet
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Want to add a second laptop to our router
if you want wired, 5 cable (network cable) just plug it into any of the open LAN port.
right click on "my netwokr" >>properties
right click on "Local Area Network">>properties
select Internet Protocol TCP/IP>>properties
select "Obtain an IP address automatically" and "Obtain DNS server address automatically"
select apply and OK, exit
if you ae going to use wireless, open the wireless setting in the control panel, follow the instruction and select the wireless network. enter the pass key. (if you have one.)
Nov 12, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Toshiba Satellite A100-S8111TD Notebook Logo
370 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
