D-Link WUA-2340 (ASKU55774) Wireless Adapter Logo
Posted on Nov 21, 2008
Installing on windows server 2008
The drivers seem to be compatible and everything, but the adapter wont blink orange showing its working.
Anyone know a fix?
Windows server 2008 enterprise
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
358
Points
Install the Wireless LAN Service feature under 'Features'
  • Anonymous Jan 16, 2012
    how do you go about doing that?
    Start>Administrative Tools>Server Manager.
    Left click 'Features' in the left pane.
    Click 'Add Features' link in right hand window.
    Scroll all the way to the bottom of the 'Select Features' window.
    Put a check mark next to 'Wireless LAN Service'
    Click next and proceed through wizard.
How can I get TP-LINK Network Wireless Adapters Drivers for windows server 2012?
No doubt you know about the HCL (Hardware compatibility list) and how if it is not there, then it will not work.
tip
Getting Blue Screen on Dell laptop with Win Server 2008 R2
I talked to a Dell rep yesterday and was telling him that my new Dell laptop (in my case an E6510) allowed me to load Windows Server 2008 R2 but I kept getting the Blue Screen of Death (BSOD) every so often. He said it was the drivers for the chipset and that I should just upgrade them to the latest. He also said the Win 7 drivers for other components work fine because the two operating systems share a common code base. If you are installing Win Server just have the drivers, particularly the ones for the network adapters, handy on a flash drive, extra partition or CD when you do the server install.
on May 28, 2010 • Computers & Internet
1helpful
How to install lan driver on dh61ww board for windows server 2008
Buy a new network adapter(D-Link DFE 520TX). connect it via the PCI slot. It will be automatically detected by the system.
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
1helpful
No video, shows orange light on front which gateway says video
it sounds like your hardware is not compatable with the update. if you can restart the computer and press f12 to boot to safe mode you should be able to open the device manager from Run: by typing devmgmt.msc, find the video adapter under 'display adapters', double click your adapter to bring up the properties window, click the 'driver' tab and click roll back driver
hope this helps. please rate me and thanks for choosing enterprise computing solutions...
1helpful
Network Adapter cannot start
i think your network adapter has have a damage
i hope i can solve your problem
I would like to know can I put windows 2008 server on this server? if I can where Can I get all the driver to support it?
Server 2008 is still relatively new.
Whilst quite a bit of hardware is already supported with 2008 out of the box I would suggest doing an upgrade install with 2003 as a base.
The last server upgrade I did took a similar route and even though much of the hardware was not listed in the compatibility report It did work fine.
From what I understand (and some of the ms bulletins can be hard to follow) some drivers seem to carry over with like a backward compatibility.
If the server is not in use yet you could always get the trail version from MS just to test the theory.
Generally servers are not as picky as a regular desktp OS about a lot of the hardware.
Windows 2008 server ethernet driver for IBM X350 Server
Click here to download the drivers.
let us know the results thnx
5helpful
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
