I have a Kenwood unit. I noticed that I had a static sound coming from the center channel. So I thought the center channel was blown. I bought a new center channel and rear speakers. When I hooked them up statuc noise started coming out of center and rear speakers. I tried switching receivers and the problem stopped. When I hooked back up the Kenwood the problem started again. Do you have any suggestions on what possible could be wrong with the Kenwood reciever??
I have Denon AVR 4500, unit works fine but I change function knob it makes loud poping or thump in...
(More)
I have Denon AVR 4500, unit works fine but I change function knob it makes loud poping or thump in the speaker!
the unit was fine yesterday morning...now no sound out on any level or function..ie...
(More)
the unit was fine yesterday morning...now no sound out on any level or function..ie dvd/tuner/tv...what gives? I tried unplugging and replugging still no go is there a "reset" button/switch? someone , anyone please help.The set up is as such I run a Denon 5 disc dvd in, a vcr in, a hdtv cablebox in and a Kenwood 6 +1 cd player and an addl Kenwood recv in...(hardly use that except at Holidays). All was working fine like I said. Thanks, Geoff
I don't get any sound output from my Denon 4800 receiver. It intermittently comes but have been...
(More)
I don't get any sound output from my Denon 4800 receiver. It intermittently comes but have been mostly sound less
Hi, I have a Denon AVR-4800 to which I have connected a pair of Sony ES series CD decks. I'm using...
(More)
Hi, I have a Denon AVR-4800 to which I have connected a pair of Sony ES series CD decks. I'm using the optical connections and have the AVR-4800 inputs set to "Optical1" and "Optical2". The CD decks play fine but I can't figure out why there is no output at the analog Tape1 and Tape2/Mon outputs. In order to record from either CD deck I have to connect the RCA cables between the 4800 and the CD decks. I assumed that I would be able to record from a CD using the optical inputs since the optical/digital sigal is converted to anaolg at some point. Does the 4800 not provide an analog output from optical input sources? Or have I missed something in the setup? Thanks, Jeff
Occasionally, it switches rapidly from "HP-on" to "HP-off" but still no sound...
(More)
Occasionally, it switches rapidly from "HP-on" to "HP-off" but still no sound from speaker outputs. I can get sound from the headphones when they are plugged in. I have owned this receiver since 2001. Any assistance you can provide is appreciated!
