My HP 1410 printer keeps shooting out blank sheets of paper instead of printing
  • mke5455 Nov 21, 2008
    I canceled all pending printing documents, then it printed one page, and then went back to shooting out blank sheets of paper and still won't print
    Scholar:
  • 135 Answers
Please check every hit I hope one of them will work.
1. Changed the default paper size to A4 in Printer sitting this will work.
2. Also try replacing the printer cable, reboot both computer and printer and try reinstalling the driver after removing it from the Control Panel.
3.
If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridge are in) and do the following:
First of all, look if there is somne ink lines on the nozzle part of the printhead. If you put a paper-tissue on the nozzles and it let on paper the 4 lines (black and colors) than maybe it's useless to clean the printhead, ink is comming trough and dont know why paper comes out blank.
If there are dry:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the printhead on some sheets of tissue.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
If after that still dont work, it's bad, it's not from cartridges or printhead, it's something else... Dont know what, from a distance.
Rate the solution if it helped you!
Thx.
Posted on Nov 21, 2008
  • 19,396 Answers
Unplug printer USB cable and re-install software drivers using printer install disk.
If you do not have disk download and run driver installer from HP PSC 1410 All-in-One Printer
Start installation with printer USB cable unplugged. The installer program will tell you when to connect printer USB.
    President:
  • 1,952 Answers
To check whether this behaviour depends by the printhead perform a noozles test, you can start it accessing printer properties. If some lines are missing the problem can be the printhead, the cleaning pump or cartridges, otherwise problem is in printer settings.
  • mohammed marika thambi
    mohammed marika thambi Nov 21, 2008
    First try to make a copy from the all-in-one and check the hardware
    functionality of the printer. If we are able to make a copy fine from
    the printer, then check whether we are experiencing this issue while
    printing from all the applications or a particular application,
    depending on that we will have the solution.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    President:
  • 624 Answers
Use the HP desktop control for print head cleaning. You may also need new ink cartridges, if it has been sitting a long time without use the ink may have dried up inside. If this doesn't help you will need to remove the print heads and clean them manually. Considering the price of printers these days, it may be a much better idea to just buy a new printer. Most new printers only cost about the same as what the ink cartridges cost, and the new printer will come with new ink as well.
    Sergeant:
  • 276 Answers
Cancel the pending documents from the print que. simple
  • smarttech Nov 21, 2008
    when u give a printout are u clicking on current page option.that is necessary if you r printing any specific page only.if you click ---all--- option it will print all the pages from that particular file still if there is nothing to print in it.
    or very simple method.
    just uninstall all the drivers of your printer from the pc.then reinstall the drivers again.this will make all new settings and your problem will get resolved.this will take not more then half hour depending your pc speed.
    if you do not have installtion  cd of your printer you can get this cd here
    Drivers, Software, lost C.D....come this way!
    If you have lost you cd or don't know how to install your printer then all you
    need to do is download the drivers and software from the manufactures website
    that suits your operating system and printer.
    Drivers and software download areas for brands listed below, just click to gain
    access and then locate driver for your needs.
    Brother Epson Sharp
    Canon Lexmark
    OKI Dell HP Kyocera Samsung Konica/Minolta
    Xerox Panasonic
    PLEASE NOTE
    When installing drivers/software it is generally a good practice to -
    Delete
    old/previous installs
    Leave printers
    USB cable disconnected from computer until newly installed software requests it
    to be connected.
Why does my hp laserjet 1020 keep printing 4 blanks after each printed sheet? HELP!
My solution already posted in FIXYA.. for the same complaint earlier.pl go through..
http://www.fixya.com/support/t10478324-printer_taking_two
You need to clean the paper pick up solenoid located at down right side ...gently remove & clean it as shown..best of luck..
Aug 20, 2014 | HP LaserJet 1020 Printer
The printer does not print. It feeds paper and
Visit HP support for this problem (XP):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01853840&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443024
If you have Vista, change query to read "Printer prints blank sheets of paper" > Choose Vista instead of XP
Dec 05, 2009 | HP Photosmart 8250 InkJet Printer
Problems with printing photos. Hp Psc 1410
check the configurations again, if the problem were still there, try with other cartridges.
Aug 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
Prints out blank sheets
reinstall the drivers and if u need our technician support on this contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | HP PSC 1410 All-In-One InkJet Printer
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
My hp psc1400 pretends to print
then there might not be ink in the cartridge. put a new one and u can continue printing
Nov 16, 2007 | HP PSC 1410 All-In-One InkJet Printer
18 people viewed this question
jasbo
jasbo
