Question about Promise Ultra133 TX2 ATA Controller
Promise Ultra133TX2 runs at 66MB cannot see beyone 32GB
Changed from Ultra66 to Ultra133TX2 installed now Ultra133TX2 can boot but speed is slow and 120GB Seagate ST3120026A only has 32GB visible. The fixed the XP bootup problem. What else do I need to do?? Mobo is Intel EA81510A in a Gateway with Bios 9. Thanks
    New Friend:
Moved - to ????? unknown!
Posted on Jun 30, 2013
1) Flash the BIOS to the latest one. It's here.
2) Use this driver which is the newest one. Here.
This should fix your issue.
Posted on Dec 11, 2008
2002 jgc tranny overheating
Search installing radiator fan relay on YouTube I promise PROMISE this is your problem. Your fans just not turning on.
Mar 24, 2013 | 2001 Jeep Grand Cherokee
I have an Intek DG45ID motherboard, installed a Fasttrak TX4650 RAID card in the PCI-X x1 slot. The motherboard does not get past the BIOS post in the boot process, just after showing the boot options a...
It seems that the card might be faulty. If there were incompatibility problems, they would normally show up under the operating system (Windows, Linux, etc), not during the booting process.
From your description, I suspect that the card's BIOS is corrupt. Try getting a replacement under warranty and see if the new card works normally (it should).
Mar 13, 2011 | Promise FastTrak TX4650 4 Port SAS RAID...
Pc monitor blank
Perform a system restore to see if it will restore your settings.
May 12, 2009 | EliteGroup GF8200 MCP78S AM2+ Atx 32GB...
I cant store video files in my kingston 32gb pen drive pl tell about service center in india
Bigger isn't always Better..... most older laptops out there cannot READ/WRITE or even understand a USB drive bigger than 8Gb (some not even 4)
It may be that your 32Gigger is too big for the PC to handle and b/c this is all a function of the BIOS and USB Controller chipset in the laptop, it cannot easily be changed.
BUT... Look on the Tech sites to see if there is a BIOS update/patch or fix for your laptop to enable it talk to the big USB drives, and Download it if there is.
Then all you need to do is make a DOS boot disk, add that updater file you downloaded, add and edit an Autoexec.bat file to automatically RUN the updater, reboot your Laptop with AC/120/240volt cable plugged in, and boot from the floppy you just made.
Very important: Once the BIOS updater is launched and running, it MUST absolutely finish by itself. You CANNOT and MUST NOT stop it or let the battery die (why you need AC cable)
When it is done, it will tell you to power off and/or Reboot. This can take 1minute or many hours (sigh). When you reboot, the Laptop will read/write your massive 32Gb USB Memstick.
Get the DOS Boot disk here:
Make a noise if you need any more help
Feb 21, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Upgraded cpu- wont boot
Teresa, if you changed the front side bus to 533, your memory must have the same clock speed. Memory clock speeds are what is known as "backwards compatible" but not forwards. This means that you could put a piece of memory of a clock speed of 400mhz into a system that runs at 333mhz and it will "downclock" the memory, but you could not put a piece of 333mhz memory in a 400mhz fsb pc and expect it to run. one of two things will happen, the system will not boot at all or the syetm will downclock the processor to a slower speed. In your case your cpu must be 533mhz clock speed with pc4200/533mhz memory to function correctly.
Dec 13, 2008 | Shuttle AV49VN Motherboard
Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Aug 09, 2008 | Promise Ultra133 TX2 ATA Controller
Unable to install XP sp2 on Intel D865GBF Motherboard
Maybe having trouble with a device, remove any pci or agp cards and usb devices, use built-in video until installed.
Set bios to defaults, make sure bios is latest version.
I have found this happens with a promise ultra-100tx2 and any nvidia video card.
May be a bad install cd, if you can boot it with a dos or win98 disk/CD, copy xp i386 folder to hard drive install from i386 folder on hdd by running winnt.exe
I have installed xpsp2 on about 10 d865gbf's and 2 days ago installed xp sp3 on one with no problems. may also be bad mobo.
Jun 28, 2008 | Intel D865GBF Motherboard
Hooking up an ATA card
What ata card have you got? Do you mean PCI or AGP card?
Feb 15, 2007 | Gateway Tabor 3 (4000532) Motherboard
Promise Ultra133 TX2 ATA Controller Logo
144 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
