Question about HP Officejet 4315 All-in-One Printer
Want to use the printer, but don't want the fax
In order to be able to print a document, I first have to return to an earlier date using SYSTEM RESTORE (Win-XP). This is a pain in the neck, but if I don't do it this way, the printer starts going through "dialing" and since it isn't connected to a phone line, I get all sorts of interesting messages.
Have been all throuh the manual - nothing compares with this sort of problem.
  • 300 Answers
I would suggest that you disconnect the usb cable from the printer. Then uninstall all programs related to the printer through Add/Remove Programs in the Control Panel.
After restarting the computer with the printer still disconnected you can follow the directions below to download the latest drivers.
To download the drivers you can go here. When the page opens you will need to choose your operating system. Then, from the Drivers section I would choose the full feature driver.
Once you click that, you will see a Install Now button that will allow you to immediately install the software and/or a Download Only button that will allow you to download the file for later installation.
Either option will have a link below them that says View Directions which can be used to get step by step instructions for installation of the drivers.
Hope this helps. Please rember to rate this information.
Thanks
Posted on Jan 04, 2009
How do i set the time and date for faxing on a canon mx410 wireless printer
Press the Menu button repeatedly to display Device settings
Use the left/right arrow buttons (the - and + buttons) to Select "Device user settings", and press the OK button.
Use left/right arrow to select "Date/time setting", and press OK.
Use the numeric keys to enter the date and time (in 24-hour format) and press OK.
Press the FAX button to return to standby.
Mar 26, 2012 | Canon Pixma MX410 All-In-One Printer
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
HP C4680 Goes Offline
Hi
Just a thought, did you use the HP CD that came in the box?
Go to Apple's website and look under the support - downloads section. You'll find a mega-sized download of up-to-date HP drivers. Download it and install it.
Then open the print and Fax setting in system preferences and remove the existing HP printer, You should then have no printers listed in the printer box.
make sure the printer is connected to the macbook and switched on and then use the Plus symbol to add a new printer. In less than a moment your printer name should appear in the empty space. Select it and wait. You should then get a thing saying 'Print Using...." It should fill in automatically with info about the driver being used.
Do what ever it asks and then close the window and see if you can print without the earlier problems.
May 04, 2010 | HP Office Equipment & Supplies
Always when printing out from my email it takes very long until it starts to print ,any tip ??
Open control panel.
Start->controlpanel ->printer and faxes.
Right click on printer then click on property.
Click on advanced
Then enable start print immediately.
Also go to start ->run type "cmd" in run then press enter
Then type in command prompt "net start spooler"
then press enter.
Then check.
If still same issue then change usb cable and also uninstall old driver then reinstall driver.
Let me know if you need further assistance.
Thanks.
Oct 25, 2009 | Computers & Internet
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Problem and credit card payment already submitted on canon pixma Please advise. Problem with fax memory, can't print faxes
1 Press [FAX], then press [Menu].
2 Use [< ] or [> ] to select <MEMORY REFERENCE>.
3 Press [OK].
4 Use [< ] or [> ] to select <PRINT DOCUMENT> or <DELETE DOCUMENT>.
▼ If you select <PRINT DOCUMENT>:
1. Press [OK]. 2. Use [<] or [> ] to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the Numeric Keys. If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
3. Press [OK]. 4. Press [< ] to print the first page only, or press [> ] to print all pages of the document. 5. To print another document, return to branch-step 2, or to finish printing, go to step 6. ▼ If you select <DELETE DOCUMENT>:
1. Press [OK]. 2. Use [< ] or [> ] to select <ALL PRINTED DOCS.> or <1 DOCUMENT>. – <ALL PRINTED DOCS.>: Deletes all the printed documents stored in memory.
– <1 DOCUMENT>: Deletes a single document stored in memory.
3. Go to step 5. 5 Press [OK].
▼ If you selected <ALL PRINTED DOCS.> above:
1. Press [< ]. Press [> ] to cancel deleting, and the machine returns to the standby mode.
If you selected <1 DOCUMENT> above:
1. Use [< ] or [> ] to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the Numeric Keys. If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
2. Press [OK]. 3. Press [< ]. Press [>] to cancel deleting, and the machine returns to the LCD of branch-step 1.
4. To delete another document, return to branch-step 1, or to finish deleting, go to step 6. 6 Press [Stop/Reset].
Sep 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MX310, says receiving fax but nothing comes out.
michael885 -
Your unit has a certain amount of memory designed to store faxes... if they are stored there, here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Aug 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Does printer need to be connected to a pc?
From the Brother website: The MFC-5440cn offers both a versatile flatbed and an automatic document feeder with faxing and copying that don’t require the use of a computer. Add to that the spectacular high-resolution printing and scanning with both a USB 2.0 full speed and an Ethernet interface and you have the perfect all-in-one for the Small Office/Home Office user to create and print professional color documents. You can even print borderless photos.
Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Brother MFC-5440CN All-In-One InkJet...
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
