Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer leaks water!
We have an amana br18v1 bottom freezer and it leaks water out the front almost daily. why is this? i've researched to see if there is a recall on this particular model, but came up with nothing. help!
  • clutchtx Nov 23, 2008
    When a repair tech came to fix our leaky bottom-freezer, he said the drain pipe was extremely small (narrow diameter) and was getting clogged with food bits from the refrigerator section. I questioned this, but he said that's all we had to do was thaw/drain/clear it manually.
    The freezer completely freezes up (1" thick ice on the bottom) monthly and leaks onto my floors and I'm fed up. Is there a larger drain tube we can install??
    Scholar:
  • 76 Answers
Luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
Posted on Dec 22, 2006
Where does Amana bottom freezer drain discharge to? I have manually defrosted the freezer. Water dropped into drain. Now water leaking out of the bottom at side of unit.
The defrost water drains into a holding pan and is evaporated away. The video displays the most likely problem.
https://youtu.be/_MyOFwRWRTY
Oct 22, 2017 | Amana Refrigerators
Freezer leaks water out the bottom
sounds like your defrost drain line is clogged or unhooked, you will have to remove everything from the freezer and take the inside back cover off to check the problem.
Mar 22, 2014 | GE Refrigerators
Buildup of ice on bottom of freezer compartment. Ice then melts and leaks out the bottom
sounds like you have a stopped up drain line where water drains out when freezer is in defrost mode. My Amana freezer does it quiet often.
Jul 15, 2012 | Amana ABB2224WES Refrigeration :...
Our amana bottom freezer refrigerator Model ABB2224DEQ at times leaks onto our kitchen floor. We don't have an ice maker so I am wondering where it would be coming from and what needs to be done to...
This is likely water from the auto defrost operation leaking from the evaporating pan. Sounds like the pan may have a hole in it, or the hose which drains the water into the pan is leaking, The pan is at the very bottom of the unit.
Charlie
Mar 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
The freezer leaks water constantly and runs out the front.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 21, 2011 | Amana ARB220RCW Bottom Freezer...
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
My Amana ABB2257CS bottom freezer leaked water
your freezer cabinet need to get all out also the ice machine,and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday .com good luck
Jun 29, 2009 | Amana ABB1927DE Bottom Freezer...
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
945 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
