Question about Acer TravelMate 2300 Notebook
Acer Travelmate 2410 - Screen is blank
Have used recovery disks to re-set to factory settings but had to use an external monitor. That will not work now after the Recovery Disk re-boot, presumably because Windows XP Home is set to a different screen resolution not within the normal range of my BENQ FP71E monitor.
The laptop screen remains blank, as it did previously, but may show, after a short time, coloured vertical lines.
The sound card seems to work as it plays the music for the Windows Tour.
Can it be the screen or maybe the graphics card onboard the M/B?
Any help would be much appreciated.
  • 3 more comments
  • mike-m5 Nov 21, 2008
    The screen never shows anything after the vertical lines appear.... cannot see Windows XP at all!!
  • mike-m5 Nov 22, 2008
    Apart from coloured stripes, the screen doesn't show anything. It's effectively blank so I can see nothing to be able to carry out any instructions to Windows,DOS whatsoever.
    Hi Dave,
    Thanks for the suggestion of FN + F5 keys, but it doesn't help with the external monitor. All I get on that display is a warning sign, "Out of Range". I have been into the Acer 2410 bios (pressing F2) and set everything to default values. At this point, the external monitor works. The Acer screen then shows some life, a dull glow, but then the Benq monitor shows nothing but the warning.
    However, I seem to be off the original thread when asking about the TFT display or the onboard graphics. Any other ideas my friends???
    Kind regards,
    Mike
    I AM MORE CONCERNED ABOUT WHAT IS CAUSING THE LACK OF DISPLAY ON THE ACER TFT SCREEN - COULD IT BE THE SCREEN, THE INVERTER OR EVEN THE ON-BOARD GRAPHICS CARD CAUSING THE PROBLEM ?
    Yes, Benimur's comments were particularly helpful. I just needed to know the percentages as to whether it was the LCD screen itself or M/B graphics. Whichever way you look at it, the laptop is probably scrap anyway, so, it looks like I'll be buying a new one.
    THANKS FOR YOUR HELP BENIMUR....
  • 849 Answers
I ASSUMED THAT UR SCREEN HAS OUT OF ORDER DUE TO LOOSE CONNECTION OR SO, BETTER TO GET SOME TECHNICAL SUPPORT FROM A AUTHORIZED SERVICE CENTRE.
Posted on Nov 22, 2008
    Master:
    Sergeant:
  • 461 Answers
If you are using the external and it works.. your LCD screen is gone.. you need to get it replace. assuming your LCD works fine before you restore the factory setting.
  • Acer Master
  • 19,396 Answers
Vertical colored stripes on your screen means:
Bad LCD ribbon cable.
or
Bad LCD display.
Very but very rarely is a bad video adapter on motherboard.
Tou need to go to a repair shop, or to send the laptop for repairs.
The technician will remove the upper panel, undo the hinges, open the display remove and test cable and replace either one.
Here the job is about $100/$150, depending if the problem is the cable or the display.
Regards.
  • Ginko
    Ginko Nov 22, 2008
    or
    Bad LCD display.
    WEhen it is a faulty inverter you also get dim screen.
    Regards.
    Sergeant:
  • 276 Answers
Either your graphics agp slot needs the driver updating or the card itself is faulty, check the agp slot for dust and gently moneuvre the card in the slot to see if the lines appear to change and check that therea are no bent pins in your connecting plug or card.
Posted on Nov 21, 2008
    Brigadier General:
  • 6,966 Answers
Sorry to be bringing you the bad news, but it would appear that your Acer Travelmate 2410 laptop has:
  • a defective LCD display panel (most likely);
  • the graphics/video chipset is defective (least likely).
Additionally, I doubt if the BENQ FP71E is not capable of displaying the resolution after the re-install. Have you tried pressing Fn + F? keys? The F? would be the F key with the small monitor icon. You may need to press on the combination of Fn + F? several times to cycle on LCD only, LCD + external and external only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Sergeant:
  • 207 Answers
It may have switched back to display mode ONLY for the laptop monitor.
Try pressing <Fn> and <F5> a few times and see if that gets the display on the external to come on.
Hope this helps
Dave
    Genius:
  • 1,011 Answers
Sir,
I think u didn't install the motherboard drivers of your software. If installed right click at desktop-> go to properties-> Go to setting tab check if it is Selected Highest 32 bit and also adjust the screen resolution to 1024 by 768 or 1152 by 864 try to change these settings..if it is not listed, it mean u would not properly installed the drivers including monitor.
Thanks
good luck
    Genius:
  • 1,550 Answers
Graphics card can be the reason for screen showing some delay in coming .
  • SAM ANDERSON Nov 21, 2008
    Have you tried upgrading BIOS to most current version.
    There is some chance that voltage settings for video chipset may be wrong .
    Make sure the video cable is properly connected to the motherboard,
    reset the connection.
    Unplug the cable from
    the motherboard, take a look inside the video connector.
    Check if there
    are any bent pins inside the connector.
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
I need to factory default set my Acer Travelmate 2490. I do not have any recovery disks.
For Recovery Disk here's the link:
http://www.user-guides.co.uk/cddownload/Acer/AcerTravelmate/Acer-Travelmate-2490-XP-Driver-Recovery-CD-Restore-Disk-1093.html
The fact is according to this website, it's not free.
Jan 11, 2010 | Computers & Internet
Acer TravelMate 8200 recovery and system disks
Your hard drive has a hidden partition that contains the original factory OS and program stored for rescue and recovery.
1 Boot to Windows.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
Dec 12, 2009 | Acer TravelMate 8200 Notebook
Need a recovery disk for acer travelmate 290
do u have another laptop or pc.
if u have open google then open isohunt then.
1st download nero iso maker
2nd download recovery disk for ur laptop
then u nid a 4.7 gig blank disk then burn the recovery disk
Dec 12, 2009 | Acer TravelMate 290 Notebook
How do i restore my acer travelmate 2700 to its factory settings?
When you first boot the machine at the bios screen hold the ALT key and press F10 this should start your acer recovery.
I would visit the acer site first and download certain drivers, ethernet or wireless etc and save them to disk or USB storage etc
if i can help further let me know
Nov 20, 2009 | Acer TravelMate 2300 Notebook
Recovery CD
Other way to restore ur notebook to factory default settings without recovery disks is
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
U can make a new set of Recovery disk when ur OS is running u will see Acer Empowering Technology with e sign kindly select ERecovery in the options and then u can make full backup of ur OS thru it
Pls rate me FIXYA fo rhelp
Apr 11, 2009 | Acer TravelMate 2451WLMi Notebook
My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Dec 11, 2008 | Acer TravelMate 2451WLMi Notebook
Acer laptop with broken screen recovery
press F8 key if u get try to enter in last known godd... also in safe mode change resolution settings to 800*600 or 1024*768.
Sep 29, 2008 | Acer Aspire 3680 Laptop
Pink/Green Background Acer Travelmate 2410
you are having an lcd experience of the 3rd kind..i'd venture to say your in for a replacement event.
Feb 27, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
