I have a new hp Photosmart C7200 all-in-one and cannot work out how to get an activity report on faxes sent and received. I do get a sent report, one at at time as they are sent but I am looking for activity histort. Thank you. can not get an activity report for fax sent/received on my C7200 all in one.
    Genius:
  • 2,120 Answers
Look for something in the menus called JOURNAL PRINT
Posted on Nov 21, 2008
How long will my fax machine hold my send/receive data for? will it save for 4-5 years?
Sorry. Your reception and transmission report data changes as it is used.
The Fax Log shows the specific information concerning transmission or reception activities, the time and date of most recent 40 transmissions or receptions.
Y
yyyyyyyyYYYYY
Nov 19, 2014 | HP Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Photosmart c309a fax confirmation?
To enable fax confirmation via the device control panel
1. Press Setup.
2. Select Print Report, and then Fax Confirmation.
3. Select one of the following: On Fax Send, On Fax Receive, Send &
Receive
4. then press OK
Dec 11, 2009 | HP Photosmart Premium C309A All-In-One...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
I need to get a copy of a document that I faxed.
No, the JOURNALS will only tell you the fax number it was sent to.
Feb 13, 2009 | HP LaserJet 3330 All-In-One Printer
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
FAX back
Do you mean to get the paper document back out of the machine? If it doesn't feed out automatically, it may need to be repaired.
If you mean that you want confirmation that a fax was sent, you can turn on the TX (Transmit) REPORT. This will print out the first page of a fax sent successfully.
1. Press the Additional Functions button.
2. Use the arrows to select FAX SETTINGS. Press the Set button.
3. Use the arrows to select REPORT SETTINGS. Press Set.
4. Use the arrows to select TX REPORT. Press Set.
5. Use the arrows to select OUTPUT YES. Press Set.
6. Press the Stop/Reset button.
The machine will automatically print an Activity Report after every 20 faxes (sent or received). If you want an Activity Report at any time:
1. Press the Function button.
2. Press Report button (number 03 on the left side of the keypad)
3. Use the arrows to select ACTIVITY REPORT.
4. Press the Set button.
Apr 17, 2008 | Canon PC-1080F Plain Paper Laser Fax
123 people viewed this question
jasbo
jasbo
