Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Refrigerator door has stopped closing automatically
We have NOT moved the refrigerator. Nothing has changed.
This is a Whirlpool side-by-side Refrigerator Model #ED25RFXFNOO. Not sure if that matches up to the product listed below as the info on our refrigerator says it is a 25.2 cu. ft.
Thanks for your help. Jan from Tucson
  • rocky140 Mar 07, 2009
    my door fell off and with the bolt coming out. Put the bolt back in and it worked for a couple weeks. Now the doot just won't stay closed. I now use a bunge cord and/or duct tape to have it stay closed. This is not the same frig but one with a top freezer and bottom frig. The bottom door is the problem.
  • 833 Answers
You may have a worn door bearing.  Have a look.  Both sides have the same hinge assembly for comparison.  Also possible that the hinges have come loose.
Clean out the hinge by spraying on a little WD 40 first...it may fix everything.
Posted on Nov 26, 2008
Whirlpool American side by side fridge/freezer is making a clicking noise. Sometimes it lasts a few minutes and other times it can last over an hour. If I open the doors its stops and as soon as I close...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Whirlpool ED2FHEXN Side by Side...
Whirlpool side by side refrigerator door not closing by itself. Ideas?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator door won't stay closed
Pull on the gaskets some times they are broken and will take up moore room that when correctly aligned. especially on the side of the door where the hinges are. Inspect thehinges also see of brackets are loose. If the gasket is bunched up on the hinge side try duct taping them down and retry the door. If this corrects problem replace door gaskets. If a plastic grommet is missing in the door it will nolt align correctly and you will be able to pick up on the outer corner of the door and it will wobel and be loose on the hinge. ReplACE THE GROMETS and retest and align as nessary.
Jun 19, 2009 | Refrigerators
Refrigerator Door Does not Close Properly
Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
May 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kitchenaid refrigerator side by side, refrigerator door will not close on its on like it use to. Model #KSRS25qDWH01 bought in 1996. If we give it a push it closes fine. But it use to close nearly b
order a cam and stop for the affected door. it is on the top of the hinge and the bottom of the door, you'll see the two pieces if you look where the door contacts the hinge, call a dealer for the correct part numbers.
May 04, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
How to reset water filter indicator on whirlpool american fridge freezer
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
Mar 09, 2009 | Whirlpool ED5VHGXM Side by Side...
Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Dec 28, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
120 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
