Question about Lands Phones
We just bought the uniden DX18560 5 days ago. we cannot get dial tone on either hanset......what can we do to fix this.
We founde the problem was in the lines. Thanks !
Posted on Nov 22, 2008
The problem is with my uniden phone model D1364 can't hear the tone when dialing phone
If you can't hear the dial tone, try substituting another phone to detect it. Also, if your Uniden phone is defective it can disable the dial tone when connected to the line.
Mar 08, 2014 | Uniden DECT 6.0 Cordless Phone ID
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Ux-p100 fax dont have a dial tone
Check your phone line by plugging a spare hanset into the wall socket (Incoming line) and listening for a dial tone on this. No dial tone - faulty line connection.
Also check you have plugged in to the correct socket on the back of your fax.
Dec 09, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
I cannot answer calls - the base has the message "answer off"
The phone apparently fixed itself. After not working correctly for a couple of days, this morning it was functioning like it was 3 days ago. I get a dial tone, and the caller ID works. I have no idea why.
Sep 04, 2009 | Uniden Cordless Phone
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
No dial tone
no dial tone. the handset shows "searching".
Nov 08, 2008 | Uniden Cordless Phone
Bought phone EX18560 Series yesterday. floolowed instructions to charge. Today I came home from work, plugged in telephone jack. phone will not turn on. Attempted to re-register (4X's). Led flashes....
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Aug 11, 2008 | Uniden Lands Phones
Dial Tone but won't call out.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
Jul 26, 2008 | Uniden Cordless Phone
Lands Phones Logo
73 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
