Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Sharper Image, Ionic Breeze, mdl. S1867. After two minutes operation it quit. All lites out and no function. Dissembled and found high voltage line shorted out to near by metal casing. Part no. on hi voltage transformer, XFR097-4, ,JF0501-03112. Checks I might do to determine if this transformer is bad. It has yellow, black and red input leads with one more insulated red output lead. Tom Hayden
  • farizpe Mar 07, 2009
    I HAVE SAME PROBLEM AND, YES THAT PART IS DAMAGE
    IF YOU GET TO KNOW WHERE TO BUY IT, PLEASE LET ME KNOW. AND IF I DO FIRST I WILL TO YOU..
Bubbabear64
  • 2794 Answers
SOURCE: Ionic Breeze GP Sharper Image
Sharper Image ionizers are no longer being serviced. What got them into trouble in the first place was the fact that they were not cleaning the air and that the air they were filtering was hazardous some peoples health. This was based on data by Consumer Reports as well as the EPA. They went to court on it and they lost.
Sharper Image was offering a rebate to people who had purchased ionizers.
The Consumer Products Safety Commission is going to be making a decision on ionizers by the end of the year. It could be that they will no longer be sold in the US next year since they are ineffective and can cause health problems.
This is an industry that should have been regulated years ago just by EPA data alone. The idea that charging the air around you gets rid of stuff is a joke. In the copier industry that I work in we are told that it is bad since copiers create ozones in the same way.
Posted on Jul 31, 2008
whytfang
  • 170 Answers
SOURCE: Who repairs the sharper image ionic breeze GP
This is a repair that someone I know didafter reading a post on the net.....regarding Quadra repairs....and here is a link for repairs....its all one link....so type it into your browser or paste it.....
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=34&ProductId=591
Remove the grid assembly.
Remove the 4 screws holding the top on.
Gently remove the top as there are wires connected to it.
Once removed, find the microswitch assembly on the side. There will be 2 green wires going to this assy board (PCB).
Examine the bottom of this board. On both my units, the PCB wascorroded badly on the trace that runs from the center lead to the wireconnection. This will cause the microswitch to quit working.
What I did was soldered a wire from the center contact of themicroswitch (center piece coming through the board. There should be alarge solder pool) to the wire connection at the edge of the board.This just 'goes around' the corroded PCB trace.
Worked fantastic on both ionic breezes and took about 5 minutes for thesecond one. The first one took over 2 hours just to find the problem.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
Posted on Apr 01, 2009
  • 4 Answers
SOURCE: Sharper Image Ionic Breeze GP S1719
I just typed in an msg on how I fixed mine. Im an old lady, and figured what the......... cant hurt. so check my msg here somewhere, and start taking out the screws. good luck, in the last couple of hours, ive fixed two of them, just cleaning the contacts. good luck to you.
Posted on Apr 23, 2009
SOURCE: Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Posted on Jul 16, 2009
  • 28 Answers
SOURCE: my ionic breeze s1867 turns on and off will not stay on
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Posted on Mar 09, 2010
Is there ozone released from The Quadra Sharper Image #S1867 ? And if so am I causing a health problem by using it/
YES!!!!! please remove it from your home as SOON as possible it is deadly ozone and these machines have been outlawed in the state of california
Jun 28, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
My ionic breeze s1867 turns on and off will not stay on
Mar 02, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
Dec 11, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Aug 27, 2008 | Sharper Image Professional Plus Ionic...
My Ionic breeze does not work
Ionic Breeze machines are no longer supported. Sharper Image recalled the whole product line based on data provided by Consumer Reports as well as the EPA. Sharper Image tried legal action and lost forcing the company into bankruptcy.
The Consumer Products Safety Commission is expected to make a decision on ionizers sales in the U.S. by the end of the year. It's looking like these production won't be selling in the U.S. much longer.
Jul 26, 2008 | Sharper Image Ionic Breeze Air Freshener...
Sharper image ionic breeze air cleaner
Jul 15, 2008 | Sharper Image Professional Plus Ionic...
SHAPER IMAGE OUT OF BUSINESS
Sharper Image has recalled all Ionic Breeze Ionizers. This is what put Sharper Image into chapter 11.
For information see the link
See the EPA link as well
Jul 12, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
My ionic breeze, quatro, quit working, no power. Can you suggest repair. Note, not an outlet problem andy
May 04, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
266 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
