Question about Fisher and Paykel DEGX1 Electric Dryer
How do I bypass a door switch for my Whirlpool dryer-
My door switch broke off and I am wondering how to bypass it
  • nojelle2002 Nov 22, 2008
    Thanks!!!!!!!! I bypassed the door switch with the information you gave!!! Yeah! dry clothes!!
  • 370 Answers
Take the top loose on the dryer to acces the door switch. If it is the old style it should have a metal suround over the black switch. If the metal arm piece has broke, Ttake it off and tape the white button down to make it run.
Posted on Nov 21, 2008
  • jonny dep Dec 22, 2012
    Mine did not have such a black switch. So, I had to cut and splice wires instead. However, mine has a light in the drum which is supposed to turn on when the door is opened. Thus, the door switch had three wires leading to it. One came from the drum light, one came from the control panel and one went to the grouns/common. I had to track down the wires using the wiring diagram (typically tucked inside the control housing) to determine which is which and then connect the wire from the control unit to the common/ground. This of course disabled the light. However, I do enjoy snatching items from the dryer without having to restart. This is also a good temporary fix until your new switch comes in. Of course, if your switch is not broke, you can just tape the switch closed.
417.84052500 electric dry 05 model safe mode code. Everything lights up but won't run
Rocky, Could be door switch problem.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bypass dryer door switch Whirlpool
Dryer Not Starting How to Test the Door Switch
. Whirlpool Kenmore Dryer Repair 01 Won Start or Run Door Switch 3406107...
Mar 13, 2016 | Kenmore Dryers
Dryer has no power. I think it has something to do with the door and the door switch
you are probably right. try pressing in door switch with screwdriver and pushing start, does it run? if not remove switch jump across door switch does it run? if so replace switch or just leave bypassed and tape up well.
Mar 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer machine whirlpool does not spin
Be sure the child lock switch is working. If the door is not closed,it won't spin. If the switch is broken, it will not spin.
My door switch broke way back when.I bypassed it.Not a good Idea if you have children.
Feb 21, 2013 | Whirlpool Dryers
Door switch broke
The drier will not operate without the door being secured for safety reasons. There is power running to the switch and once the door is shut and the lever,or the "spring" is pushed in it allows the power to turn on.Almost like a light switch. The door switch will have to be replaced. This is a very easy repair. The switch can be found at your nearest appliance store or online.
Oct 26, 2012 | Roper RES7646KQ Electric Dryer
How to bypass a door switch actuator level to a dryer estate
The only solution that comes to my mind is to snip off the wires on either end of the switch and fuse them together. The dryer will run even when the door is opened.
May 06, 2012 | Whirlpool Dryers
Wont turn on
if your light is coming on, it may be your door switch, you can bypass the door switch and see if the dryer will work. Hope this helped tim
Sep 07, 2010 | Whirlpool WED6200S Electric Dryer
*my whirlpool dryer model LER4634EQ1,serial MG2203726,will not run and i was wondering how do i by pass the door switch and the push start button
Just tape the two lid switch wires together and this bypasses the lid switch. Its not neccessary on start button
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Sep 01, 2010 | Whirlpool Dryers
The dryer will not start
thermostat would not cause it not to run if the white thermal fuse has continuity ck the door switch to be sure lever is not broke also ck breaker after switch timer most logical but unless you know to ck best not just guess could be expensive
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
Door switch broke off
no either replace door switch or bypass it ..remove screws at filter opening(if its a top mount filter) pop clips each corner at edge of and lift top switch
Nov 16, 2008 | Whirlpool LER4634J Electric Dryer
Dryer will not start
could be the start switch might be gone,there is a clip the hang down when u open the dryer door,it might be broke or the belt might be broke.
Mar 22, 2008 | Whirlpool LER5636P Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
2,301 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
