I HAVE A RCA R401A1 HDTV THE EVERY ONCE IN AWHILE THE PICTURE WILL SPLIT OFF INTO 3 COLORS RED, GREEN AND BLUE KIND OF LIKE 3D BUT WILL REVERT BACK TO REGULAR TV AFTER AWHILE OR IF I SHUT IT OFF AND TURN IT BACK ON
  • walkerak1741 Nov 21, 2008
    my rca r401a1 hdtv seems to be in 3d sometimes a green picture with a red picture and a blue picture all on the same screen 3 different pictures like 3d. i turn off tv and it goes back to normal or sometimes it only last a few seconds and goes back to normal..
    you are correct the model is a R52WH74
  • 19,396 Answers
That is a convergence problem, probably one of the two stk ICs on the convergence board is starting to fail and you get the typical color splitting picture.
Posted on Nov 21, 2008
    Genius:
  • 1,011 Answers
Sir,
we have to pull off the front of the tv. behind the speaker grill is a panel. remove the panel. there is a black box there hanging. it has 6 controls on it. 3 are marked focus and 3 screen. we want to adjust the screen. if yoy turn these too high you can damage a tube. so we are doing real small adjustments. turn the color off on the tv and ajust the red and blue controls up till you get a black and white picture. right now you have a green tint with the color turned off.
thanks
good luck
    Brigadier General:
  • 6,966 Answers
Initially, pls post back the exact model of the RCA TV. The model R401A1 is for the remote control. Normally, RCA TVs have models like R52WH76. In some designs, your posted/described problem would indicate a cold solder or heat related issue and not necessarily a defective component. If attended to early, then the fix would be relatively easy, re-solder. Often the culprit maybe found in any of the ICs' pins. In other models, this maybe the convergence ICs, again depending on the model.
In any case, the unit has to be opened up. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 21, 2008
    Appreciate the postback on the correct model number, R52WH74. Below are some information which you may find useful:
    • for an RCA R52WH74, the chassis number is ITC222A;
    • more often than not, the convergence board would require looking over. I suspect as earlier stated cold solder. With this in mind, all that is needed is a soldering iron;
    • incidentally, a more pronounced version of your problem has been addressed on this site by one of the resident experts, Slinteriors, who has repaired and provided information for similar issues. If you would click on the link to his name, it would open to his profile page and you can then proceed to do an "Ask Me", that is to direct a question to him;
    • alternately, you can try http://servicemanuals.vstore.ca ;
    • pls reference pages here and here;
    • the service manual should you be interested is available likewise at http://servicemanuals.vstore.ca/.
    • and no I am not affiliated with Slinteriors or http://servicemanuals.vstore.ca/;
    • I actually am across the globe.
    Cheers.
    Sergeant:
  • 276 Answers
The ic of the tv which controls the colours in the tv is either got loose.or at the last stage of becomeing fautty. open the tv and on the main board there it is you have to check those ic and make it proper. thanks.
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Color is splitting, and almost looks 3D.
the ITC222A convergence option missing repair kit at the following link should repair that issue. The kit contains the parts and the instructions on CD
http://www.tvrepairworld.com/
Jul 19, 2009 | RCA R52WM24 52" HDTV Projection Television
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Picture problem with rca 52 inch hdtv colors split not in focus
Hello, If your picture looks like a "3D image" you need convergence IC's . Red and or blue picture is not converging on top of the green picture. They are mounted on large, finned heat sinks. The # on the IC's starts with "STK-" followed by numbers.They are available through tritronicsinc.com for $15 to $35 each. Good luck.
barneyluc
Oct 10, 2008 | Televison & Video
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Open Questions:
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
