Question about Miele Washing Machines
Miele WT 2679 door lock
I have a Miele WT 2679 washer dryer. I have just finished washign and drying, the program has ended, but I cant release the door. When I press the door release button it say that the door is locked. How do I unlock the door?
  • 58 Answers
SOURCE: front load washer
LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
Posted on Oct 31, 2007
SOURCE: AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Posted on Mar 25, 2008
  • 5 Answers
SOURCE: washer won't drain
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
SOURCE: washer and dryer do not work
wires were shorting each other out that go into plug - once took apart saw the sparks so just cut and shortened wires and reconnected them to plug
Posted on Feb 01, 2009
BIKER T
  • 909 Answers
SOURCE: Zanussi ZWD1261 works fine except doesn,t turn off at end.
There is an issue with the timer . Needs to be replaced if it worries you.
Posted on Sep 20, 2009
Miele washer does not power on at all
check the door switch or the mains fuse. they are both on the inside.
Feb 15, 2016 | Miele WT 2780 Front Load Washer
My miele wt 2679 wpm has appeared waterproof system activated.how to deactivate it.
Make sure the door is closed, then pull the plug out of the wall or turn off the 15 A breaker at the panel for 30 secondsd, then plug back in, or turn the breaker back on.
This is like a hard boot for a computer or to clear a problem which is locked like this.
That is the first easier fix to try first.
I hope this may help!
William R
Mar 27, 2015 | Miele Washing Machines
Why is my Miele WT945 front lader washer dryer not taking water in properly or at all?
you may try cleaning the inlet screen by removing the fill hose.then pry the ccreen out with a small screwdriver.
May 05, 2014 | Miele WT945 Front Load Washer / Dryer
Kenmore elite he3
most front load washers and dryers have locks on the doors some have a bottom panel that u can remove to manually unlock door using the release before opening any machine please unplug machine from wall sometimes even unplugging it and waiting a few seconds will release door lock from itself
Feb 09, 2014 | Dryers
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Machine started with door not shut
to release the door lock you have to pull the outer door and inner door away from each other at the top. if you have a wood panel, pull the handle of the wood panel away from the stainless steel inner door panel. you will notice the outer door panel will move out about a quarter inch. you will then hear the latch pop open. once you do that, close the door and select your cycle as usual.
Jun 22, 2012 | Miele Incognito G818SCVi Built-in...
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
'Close the Door' on Miele WT 2670
Door lock faulty or wires to lock adrift.
Mar 06, 2010 | Miele WT945 Front Load Washer / Dryer
Washing Machines Logo
112 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
