Question about Kirby Vacuums
How do you change the dirt bag on a kirby vacuum?
  • 55 Answers
Most Kirbys have two tabs on the inlet hole that line up with two notches on the cardboard face of the bag that lock it into place Grab the cardboard part of the bag and turn it about 30 degrees to the left while pulling out on it and the bag should pop right out.
Posted on Nov 21, 2008
My Kirby is not picking up correctly, almost just seems to move fibers around.oves fibers, dirt around .Brush is engaged, green light is on. Any idea what's going on?
look for a blockage in the head elbow of the suction pipe or in the pipe itself
check foe air leaks that lessen the vacuum
Feb 15, 2016 | Kirby Vacuums
How to replace filler tube on Kirby G4 vacuum?
first take cloth bag off, held on at bottom with bag clamp, then wash cloth bag in washing machine at 40, inner hose is held on by 2 cable ties top and bottom, your new hose should come with 2 new cable ties, ask kirby agent when ordering, them simply refit.
Aug 25, 2014 | Kirby G4 Bagged Upright Vacuum
Need Kirby Generation 3 Vacuum cleaner manual. Vacuum is not picking up dirt from floor. Seems to have enough suction to inflate the bag, but when you check the suction under the vacuum, there seems to...
If your brush roll is turning and your bag is not overly full, then the only other thing it can be is a clog where the bag connects to the vacuum. Turn the plastic part out away from vacuum and lift off to see if you have something clogging it. It would have to be something big, but not so big that it could not get past the fan. As a rule of thumb, KIRBY never clogs. I suspect that your belt is stretched out and your brush roll is not turning while on the carpet so the brush roll is just in the way rather than brushing your carpet to pick up dirt.
Jun 08, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Fix for broken tubing leading into filter bag?
You can replace the black tubing. There is no need to get a new vacuum. You can find the parts you need by following the link below.
Make sure to leave positive feedback.
Mar 05, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G3
Beginning with the G series, G3 and G4 had round openings for the dirt intake. Prior models had oval so they will not fit, so find G3 or G4 bags and you will be set
Sep 09, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby creating dirt under carpet?
It is possible that the height adjustment on your Kirby is to close to the carpet,which could account for the problem you're having.The correct height adjustment for your Kirby is this-Lower the height adjustment down until you hear a change in the sound,then adjust one more click down.The Kirby is at the correct height for cleaning.If the carpet is different in another room,adjust it the same way for each carpet
Dec 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
kirby style 2 bags if it is indeed a bagged unit, some where special order with what is called a shake out bag, if your outer bag has a short zipper with a cloth pocket it is a shake out bag in which you take the assembly loose from the machine and open the bottom of the metal empter and take out side and basically shake out the dirt. and use the pocket to help get out the dirt. but most of these machines did take a style 2 bag in which you unzip the outer bag and pull the paper bag away from the tube and reinsert new one onto tube and finally zip up bag
Mar 28, 2008 | Vacuums
Vacuums Logo
47 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
