Question about RCA Universal Remote Control
I have a durabrand and none of the codes supplied work
I tried all the code search and entry modes nothing worked
  • 35 Answers
I have durabrand codes, 10463, 10180, 10178, 10171, 11034, 10003
Posted on Nov 29, 2008
  • 520 Answers
If you're talking about a Durabrand(Walmart) tv, try the codes for Orion, Funai, and Haier. I hope this helps you. friend of nx.
Posted on Nov 22, 2008
I have a GE universal remote but need a code for a durabrand tv
I found this. Your make is pretty obscure!
I have Durabrand TV BH2404 the codes for the one for all URC-3021B00 in the book are 0178, 0180 on the webpage they also have 0003, 0171, 0463, 1034 none of them work I tried to manually search for the codes for 30 min no luck does anyone know any other codes to try?
Emerson also work apparently
Emerson01,03,04,23,32,34,35,77,81,83,84
May 17, 2016 | GE Televison & Video
What is the code for a universal remote in order to tune telefunken mp514 tv
These are the universal remote codes for Telefunken Brand TVs: 0031 0000 0001
Try this method, if none of above codes work.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
If you wish to get more details check this.
Dec 31, 2012 | Televison & Video
The all for one codes i have for goodmans freeview do not work
Try Code Search Method.
Apr 22, 2012 | Televison & Video
Need a new remote. were to purchase one at. my remote is bad after replacing the batteries i checked the remote with my video cam and found the remote is bad
Hello
Just buy one PHILIPS CL 034 universal remote control Duraband is listed it its codes. Codes are:-
.......... 0520 0115 0317
........................... 0916 0027 0447 0323
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK
Mar 05, 2011 | Durabrand HT-3915 System
HELLO!.. I HAVE A DURABRAND TV. AND I HAVE NEED
Hello You just buy one Philips CL 034 model Universal remote control, which can be programmed with your Duraband TV. The porgramme codes are
0520 0115 0317 0916 0027 0447 0323
Direct Code Entry 1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. 2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes. 4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one othe other codes for your brand. Ok
Nov 27, 2010 | Durabrand DWT2405 24" TV
Ive lost my code sheet for my philips universal remote cl034 and i need the 4 digit code for my durabrand tv
DURABRAND .......... 0520 0115 0317 0916 0027 0447 0323
Direct Code Entry
button.
flashes.
Oct 13, 2010 | Televison & Video
Uverse remote connection
This process should be used if the code for the device is not listed in the Manufacturer Code List.
  1. Turn on the device you wish to program.
  2. Point the remote control at the device.
  3. Press and hold the Mode key (TV, DVD or AUX) you want to program. Without releasing the selected Mode key, press and hold the OK key simultaneously
  4. Release both the Mode key and the OK key at the same time.
    All the Mode keys will flash twice indicating programming mode.
  5. Enter code 922 by pressing the number keys on the remote control. The selected Mode key will flash twice indicating correct entry.
    Note: This next step is For AUX Searching only, press and release the PLAY key then press:
    • 1 for VCR
    • 2 for Receiver/Tuner
    • 3 for Amplifier
    • 4 for Home Theater In The Box (HTIB)
    All the Mode keys will flash twice indicating correct entry.
  6. For AUX only, press and hold the PLAY key and wait until the device turns off, then release the PLAY key.
    • The REW key can be utilized to go back through the codes one at a time.
    • The FF key can be utilized to move forward through to codes one at a time.
    • Press the PLAY key to resume auto search of device codes.
  7. To save the code, press the ENTER key on the remote control (bottom right) or press the EXIT key to return to normal operation.
    The selected Mode key will flash three times and return to normal operation.
  8. If no valid code is found, the red light will flash two times and the remote control will return to normal operation.
  9. Turn the device back on using the remote control. If this doesn’t work start over or try Manual
  10. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the AT&T U-verse TV Receiver, press the AT&T Mode key.
May 24, 2009 | Durabrand DWT1905 TV
Code for total control4 - Proline TV
i have the same problem cant get a code for my durabrand dvd recorder
May 05, 2009 | Televison & Video
TVTECH Universal Remote (3 Devices)
i got a universal remote it dont have my code in the book i have a durabrand tv do you have any i deal what the code is
Nov 08, 2007 | Televison & Video
Universal Remote Control codes
use the codes 520, 115, 916, 027. i just used them for my durabrand 13 in tv. i actually used 520! it works with the phillips magnavox universal remote.
Jul 16, 2007 | Durabrand BH1304D 13" TV
Televison & Video Logo
217 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
