Question about Sony DSR-45 Mini DV VCR
Sony DSR-45 will not eject tape nor play,ff,rewind shows error
Machine shows error C3211: How can I get tape out of machine
  • kevkmw Dec 17, 2008
    I have a code of C32:10
  • 4,234 Answers
The generic error codes C32:xx indicate that a motor is not functioning. If you have not worked on these machines before, extreme caution is advised. These have extremely sensitive alignments that can easily be disturbed.
Please update this with your familiarity with these machines and I'll try to provide additional directions.
Thanks,
Dan
Posted on Feb 21, 2009
Tape loads into Sony DsR1500P but will not play or rewind/fast forward. No error code shown. Time code does not turn over.
Dear
Please play a head cleaning cassette and after using it for few seconds then play a normal tape.
Then it will show the picture.
Sep 10, 2013 | Sony DSR-1500 Mini DV VCR
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
It does not eject the tape,it gives out error c3211
Reel of the cassette must be stuck inside. open the top cover and have a look inside. release the reel if it is tangled up inside. Reset the switch at the bottom of the frot pannel and try to eject the cassette. It will slove your problem. If it is not then you must consult the nearby sony service centre.
Aug 07, 2009 | Sony DSR-45P DV / Mini DV VCR
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Sony PD 170 error code c3220 Tape will not eject.
dear,
you can restart the camera , by pressing the side button in the side of lcd pannel by a pin or some sharp thing ,
it will eject the tape after some time whne u press the eject button . dnt play hard with it
Mar 15, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony DSR 45P error code C3125
Press the power butten several times while holding down the eject button. It will solve your problem and clear the error. If it not then there is something wrong with your reel motor or the circuitery which deals the reel motor. You must consult your nearby sony service center.
Rajab Ali
Mar 08, 2009 | Sony DSR-45P DV / Mini DV VCR
Sony dsr-45 tape
It is:
Sony cleaning cassette DVM12CLD you can buy it from ebay at 15 pounds. click on the following link:
http://cgi.ebay.co.uk/Sony-DVM12CLD-MiniDV-cleaning-cassette-in-Blister-DVM12_W0QQitemZ370257959235QQcmdZViewItem
Aug 07, 2008 | Sony DSR-45 Mini DV VCR
Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Feb 15, 2008 | Televison & Video
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Oct 17, 2007 | Sony DSR-45 Mini DV VCR
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Sony DSR-45 Mini DV VCR Logo
594 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
