Question about Panasonic Televison & Video
Panasonic VCR setup
Have been given an old panasonic NV-L20HQ VCR ... cannot find how to get into menu to set channel for output to tv
Hi, I've read yr problem with the Panasonic VCR.
It's the TVset you have to switch to channel 36 to get video. When yr watching with a coax. Otherwise you're watching via scart and you just have to switch to AV.
It's some time ago your Q and I think the vcr is longtime burnt. Mine did twice...;- ) Belegian greetz
Posted on Feb 05, 2011
How do you tune a Panasonic VCR model number NV-HD100 in please
You need to connect the RF ( cable or TV) to the input and connect the output to the TV. Now select the menu to auto scan the channels. The you can select timer to set the channels,time and date.
please find the link below for support.
http://www2.panasonic.com/consumer-electronics/support/Video/VCRs.75427
Apr 05, 2011 | Video Game Consoles & Games
Panasonic =iv NV-MV40 , how to set the clock please
You can download the user manual for free from the Panasonic website.
Apr 03, 2011 | Televison & Video
Cannot setup to get all digital channels. Instructions no help
Try selecting factory default, this might clear any old information stored on the vcr. You should then be able to rescan and get them all.
Sep 14, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Aug 15, 2009 | Panasonic Televison & Video
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
My Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Sep 01, 2008 | Televison & Video
Problems using video to record from tv
The tv has 3 scarts try connecting to AV3.
If still no luck go to the TV Menu and then 'Setup Menu' find settings and change AV2 OUTPUT TO TV.
Nov 11, 2007 | Panasonic TH37PX60 37 in. Plasma...
Programming panasonic vcr
First, check in the VCR setup and see if it set for cable or off-air/broadcast/antenna (not always named the same).  If it is set for off-air... then it won't tune cable channels beyond 13.  It must be set for cable mode in order to tune those upper channels (mid-band, superband etc.).
I assume you have the VCR hooked up correctly- cable into VCR antenna/RF input, VCR RF/to TV output to the RF/Ant input of the TV.
Oct 15, 2007 | Panasonic AG-1980 S-VHS VCR
Televison & Video Logo
190 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
