Question about Brother HL-2070N Laser Printer
Brother HL-2070N prints very light even with new Toner cartridge.
I've been having a lot of problems with faint printouts lately.  I replaced the toner cartridge and drum assembly but that doesn't seem to have fixed the problem.  In addition, my printer makes intermittent squeaking noises when printing and last time I tried to investigate them I could not open the toner access door all the way.  On closer inspection there appears to be a sliding arm on the left side that will not extend all the way out to allow me to open the door.  Any ideas on this?
  • 1 more comment
  • radomir Nov 25, 2008
    My printer seems to have the same problem: doors open with difficulty and it prints very pale unreadable copies. The printer is fairly new, so I don't think I need a new drum. New cartridge makes no difference. Any suggestions would be appreciated.
  • Anonymous Dec 11, 2008
    mine too!
  • pacrim50 Dec 23, 2008
    I have a Brother MFC 7420 but have the same issue. It looks to be a broken plastic piece which rotates the toner. Not sure if brother has parts to change. Not a good situation.
bluegreenash
  • 661 Answers
SOURCE: Brother HL-2070N
did you remember to remove the seal on the toner cart? this is a breakaway tab usually on the side, this when pulled removes the plastic seal,(from inside the cartridge)
Posted on Aug 17, 2007
  • 12 Answers
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
Posted on Jul 05, 2008
  • 5 Answers
SOURCE: HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Posted on Jul 17, 2008
  • 7 Answers
SOURCE: HL-2070N will not properly print
My guess is the problem is with Firefox trying to print the page and not the printer. Try to go to File > Print Preview and see if it looks normal there. If not, I have 3 suggestions:
  1. Try to change the "Page Options" or "Scale" under the Print Preview
  2. Try to install and use the Firefox Add-On "IE Tab". This gives you the choice to display the page with Internet Explorer, while still using Firefox. You can turn on IE Tab, and then try to print. https://addons.mozilla.org/en-US/firefox/addon/1419
  3. Upgrade to Firefox 3.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jerry_779afc81ec0a7712
SOURCE: BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Posted on Nov 06, 2008
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
Faint print on Brother HL-2040
Try cleaning the drum cylinder with alcohol and a cotton ball. Then swipe the corona wire cleaner back and forward making sure to return it to the correct place. Try a print. If it is improved - replace the drum at earliest convenience. If not improved - could be dirty laser lenses or problem with the fuser.
Oct 20, 2017 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Brother printer HL-2070N Stopped printing. Toner light stays on. Installed replacment toner cartridge. Rocked side to side to spread toner evenly. Cleaned the primary corona wire. Light still on. Will not...
go to the start of your computer and find the control panel and when you see the ad and remove program click it and and you see the currently install files find words brother printer HL. click it and remove after that please restart your computer din insert your brother printer installer cd into cdrm and install again maybe your current printer driver some files is missing, or reformat your pc using os/operating system and install the printer again make sure your printer have a load tuner or ink. thank you
Jul 03, 2009 | Office Equipment & Supplies
Have you removed the tape?
Try OEM toner from the manufacturer.
Good Luck.
Feb 25, 2009 | Brother HL-2070N Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
HL 2070n
Release Go
Shut door
good to go.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
106 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
