Question about IC Intracom Manhattan FUN! CAM Webcam
Video capture I reloaded windows XP and then downloaded the drivers for my webcam. When I activate it I get a error message saying " No video capture hardware. My webcan worked before I reloaded windows
  • Anonymous Mar 31, 2014
    Cant update the driver for EasyCAP
  • 76 Answers
Try another usb port first..
you may need to update your xp to service pack 2 or 3 as well.
Posted on Nov 21, 2008
Error during capture error code 800706f8
The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
windows-xp-other-device.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.
windows-vista-device-error.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
After uninstalling the software, restart your PC and then reinstall the webcam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your webcam during the software installation.
If the drivers and webcam software are correctly installed, and you still cannot see any video, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the webcam feature. If you have multiple devices that qualify for video, you might need to select your webcam device as the source for the webcam feature in that program.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
Lastly, if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
video-capture-properties.jpg Do keep in mind that not all settings will be enabled depending on the webcam and the webcam driver installed on your computer. In the example you can see that some settings are disabled. The example shows the video capture properties for an Acer Crystal Eye webcam.
What else to try: download missing webcam drivers! If you are using your webcam for instant messaging with one of the popular chat programs, have a look at EatCam, which allows you to record your webcam chats from MSN, YM, ICQ, Skype, AIM and a few more!
Mar 05, 2011 | Computers & Internet
My webcam works fine with everything, but when I use "Quick Capture" to take a photo, it says that the webcam was not found or is not working properly. I've tried to reinstall it several times as well. How...
Copy this site and paste it in your browser ADDRESS
Bar and hit ENTER;
http://www.free-codecs.com/AMCap_download.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20
AMCap is a small yet fully functional video capture application compatible with Microsoft
DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports
still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard
and Video size settings from previous session. It has some nice features like multi-monitoring support, zooming, aspect ratio and interlacing features.
program.
AMCap is a small and effective piece of software and definitely worth trying.
Hope this will help. Bud
Feb 08, 2010 | Logitech QuickCam Pro 9000 Web Cam
No video capture
Test your webcam here by hitting "Allow" in the top window and assess the picture in the left hand panel.
http://www.testmycam.com/
If its ok you know your software is at fault
Download and run this diagnostic webcam tool and check the results
http://www.download32.com/webcam-diagnostics-d35065.html
Sounds like a driver problem - you can expand the 'imaging' file in your Device Manager and right click on your webcam text - update driver via the internet when prompted.
Further assistance / drivers are available at A4Tech support
http://www.a4tech.com/ennew/support.asp
Aug 06, 2009 | A4tech PK5
Problem with Drive WJ430 - LOREX - QLR0440
Download an XP type for starters...
Jul 23, 2009 | Computers & Internet
Acer crystal eye webcam
How to Record Webcam Video with Earlier Versions of Windows Movie Maker If you're still using Windows XP, your Windows Movie Maker version might still support capturing video from a webcam. To do this, go to your WMM Movie Tasks and then select "Capture from Video Device". Select webcam from the list of analog devices. You must also select the video input line you want to use for capturing your webcam video. Then enter a name for your captured video file and the location of the drive where you want to save it. Select your video setting preferences for the video you want to capture. To stop capturing, you can either
choose to stop anywhere during the recording session or indicate a specific time limit before the recording stops.
How to Record Video on Your Webcam with Newer Versions of Windows Movie Maker When we say newer versions, we are referring to Windows Movie Maker version 6 which comes pre-loaded with the Windows Vista system. Since Windows Vista is a pretty advanced OS, we expected the latest version of the WMM to support webcam video capture as well. It's very helpful and economical since it comes packaged with Windows Vista, and you don't have to pay the extra cost just to have that tool.
So, the next question now is, how can you record a webcam video using Windows Movie Maker 6. Actually, like we said - you can't. You won't see the "Start Capture" tool in the File Menu of your latest Windows Movie Maker.
Your best bet is to look for alternative and cheaper software that would help you capture whatever you want to record from your webcam. Or, better yet, use the software that comes with your webcam to capture video and then import it into Windows Movie Maker for editing and enhancements. If your webcam didn't come with video capture software, you're in luck because there are free software appllications available for you to download to do such tasks. You can find a good list of webcam video capturing software from this list:
http://www.sharewareconnection.com/titles/webcam-video.htm
Apr 12, 2009 | Acer Aspire 5315 Notebook
I can't get Lorex VistaPro4 QLR0440 working on my XP
I had the same problem for a while till I figured out how to fix it.
go into:
start -> control panel -> system -> hardware -> device manager
in device manager go down to the "sound, video, and game controllers"
in my system there was another set of audio and video capture drivers installed ("kworldb878 audio capture" or something)
go into those, and update driver; instead of letting it search, choose the driver from the list. (lexor is the manufacturer) and then install the lexor drivers, and that fixed it for me :)
evileyejones
Jan 19, 2009 | Computers & Internet
Black webcam window
You should make your webcam driver active under the ‘Microsoft WDM Image Capture (Win 32)’ driver using the 'Options > Video Source' hot button above the preview window.
Oct 19, 2008 | Yahoo Messenger
UMAX web camera video capture hardware
Normal 0 Double Click on this site
http://www.free-codecs.com/download/AMCap.htm
AMCap v9.20 AMCap is a small yet fully functional video capture application compatible with Microsoft DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard and Video size settings from previous session. It has some nice features like multimonitoring support, zooming, aspect ratio and deinterlacing features.
AMCap is a small and effictive piece of software and definitely worth trying. Hope this will help. Bud
Sep 16, 2008 | Umax AstraPix PC100 Webcam
IC Intracom Manhattan FUN! CAM Webcam Logo
157 people viewed this question
Top IC Intracom Computers & Internet Experts
micky dee
sonyamw
Stojan Nikolovski
Stojan Nikolovski
Are you an IC Intracom Computer and Internet Expert? Answer questions, earn points and help others
