Question about Ergotron VERTICAL LIFT SLIDE-OUT KEYBOARD TRAY GRAY
Under desk sliding tray won't slide
I have my keyboard on an under the desk sliding tray that won't slide open for full use. My niece pushed the tray closed and now it won't slide. It is like it is locked.
    Sergeant:
  • 207 Answers
It sounds like She closed it with it not quite aligned properly.
First try lift up on it a bit while pulling it out some, if it's jammed it may take quite a bit of force. If you have more than one person 1 might lift and the other pull.
If this is tried with no success, you may have to go underneath the desk with a screwdriver and remove one of the sliderails in order to dislodge it. Once loose seperate the sliderails from the mounts and then reattach the mount to the desk. Then insert the rollers into the mount (Holding tray at a 45 deg angle.) Once the rollers are in tilt the tray down and push the tray in to seat it. It should click into place when it catches. It should now be able to slide as normal.
Hope this helps
Dave
Posted on Nov 21, 2008
Can anyone help me keyboard drayer it is stuck how to remove it
Posted on Dec 25, 2012
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Oct 13, 2013 | Kodak Carousel 4400 Slide Projector
Delonghi magnifica bottom tray won't go in
Hi there, I have the same type of coffee maker. I have had problems with " the black thing push". Back to the tray. Take the tray out and hoover the bottom and as far in as you can and under the " push". I need to hoover mine I can see now. 8_27_2013_9_23_31_pm.png
Jul 10, 2013 | Coffee Makers & Espresso Machines
How to take apart a metal tray slide? Like the one in desks?
Check if the keyboard tray slide rail has any screws...?
If not, i guess that means total disassembly of the desk and ofc...rebuilding back! :)
Nov 16, 2017 | Computers & Internet
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
When the projector was turned on it started to cycle as when ejecting slides then it stopped and seems to be jammed...the rectangle black screen that opens and closes during the cycle to view slides is...
First of all, remove the tray (use the emergency tray removal in the center hub of the projector). BE CAREFUL not to spill your slides, so before you remove the tray, make sure the tray ring is in position & tight, then when you remove the tray turn it upside down immediately and move the tray plate to the "zero" position. Remove any slides that might be in the gate of the projector. Turn the projector on and cycle the projector 2 or 3 times in Reverse. This should clear a tray/slide jam. Good Luck !!
Jan 24, 2011 | Kodak ABR Ektagraphic 35mm 140 Slides...
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
Need to remove a CD from DVD drive when computer won't reboot
In a laptop drive, there is a small hole in the door near the "open" button. Gently push a straightened-out paper clip into the hole and the drive will open.
In full-size drives used in desktops, the hole is usually under the tray. Again, push a straightened-out paper clip into the hole to open the tray. Once the tray slides out you can open it the rest of the way by hand.
Mar 12, 2010 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Desk drawer - slides open
my husband is having trouble installing a kitchen drawer slide--it keeps jumping off track--can anyone help??
Mar 17, 2009 | ACCO Brands Kensington Desktop Comfort...
Jvc dr-mv78 -- dvd tray keeps coming out
Try this: unplug for 1 hour. push in tray and unplug for 1 hour. No help then your timing is off internally, decks use rubber pulleys or fixed gears. Fixed gears slip because someone shoved the drawer closed, pulleys because they are old! There is no harm at this point to open it up and see what you can do ? Other wise PRO shop. Or toss and get another, Panasonic. Please rate..
Mar 16, 2009 | JVC DR-MV7 DVD Recorder/VCR
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
Open Questions:
See all Ergotron VERTICAL LIFT SLIDE-OUT KEYBOARD TRAY Questions
Ergotron VERTICAL LIFT SLIDE-OUT KEYBOARD TRAY GRAY  Logo
3,322 people viewed this question
Top Ergotron Computers & Internet Experts
David Payne
David Payne
Are you an Ergotron Computer and Internet Expert? Answer questions, earn points and help others
