Question about Goodman GMS90703BXA Heater
Goodman a/c works, heater will work fine then fan will stop
I had this Goodman heat pump installed almost 3 years ago and no one has been able to fix it. In the summer, the a/c works perfectly. When the weather turns cold (this week in South Carolina), the heater will work until the house heats up close to the thermostat setting (72 degrees, although I have tried anywhere from 65 to 78 degrees, hoping that is the problem). Then the inside air will stop and I can hear the (I assume) compressor humming loudly outside. This will continue for up to half an hour, at which point I turn the thermostat to off. Also, when I turn the fan to on, it doesn't come on. I have also learned that, when the above problem happens, I can turn the fan to on and then immediately back to auto, and I'll get heat blowing inside the house again. Help! I'm a single mother and can't afford to continue supporting my local HVAC repairmen.
  • njs7227 Nov 24, 2008
    I'll actually try that but, as for keeping the fan in the "On" position, the blower doesn't work in the "On" position, only on "Auto". I'm replacing the thermostat (which the HVAC repairman didn't replace when the unit was installed), because the fan not coming on suggests a thermostat problem to me. If that doesn't help, I'll move on to replacing the circuit board. Thanks for your help.
  • 1,420 Answers
You have a circuit board acting up. Try keeping the fan in the "On" position. It will keep the blower on all the time but it may work. There is a built-in delay not allowing the unit to come on after you reset it with the thermostat, wait three minutes or so to see if it comes back on. I still suspect a bad circuit board.
Posted on Nov 21, 2008
I have a goodman furnace that was installer 2 weeks ago. It ran fine until it blew a 3 amp fuse this morning. It works fine as long as I do not have anything plugged into the Com terminal.
c is your common, u only use it if you have ac, humidifier, or u use 24 volts for t- stat, follow the common wire and see what it feeds u do not net it for heat, could be ur ac or humidifier has a short in it
Dec 20, 2015 | Goodman Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Goodman furnace, blowing cold air
Replace termorelay cose it overheating in service centre 12_26_2013_5_48_58_pm.jpg
Dec 06, 2013 | Heating & Cooling
Goodman heating system
It really depends on the type of system you have. You will either have a furnace, high efficiency furnace, heat pump system, heat pump with gas or electric back up heat. All these systems operate differently and the problem that you are having could be caused by multiple issues, depending on which system it is. More info will be greatly appreciated. Make sure to check all filters and air flow first before going any further. The system could be over heating and tripping a limit, causing the system to stop producing heat until the unit has cooled back down.
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 29, 2017 | Goodman GMS90703BXA Heater
I have a goodman gmpn 100-4 REVB furnace that will not stay lit
If the igniter lights the burners the ignitor..... is not bad. Its like a light bulb.... it works or ot doesn't.
You are describing a dirty flame sensor. Dishonest contractors will sell you a new ignitor but clean the flame sensor when the are installing the ignitor. It is located at the opposite end of the burners than the ignitor. It has one wire going to it. Remove it and clean the rod with a piece of fine grit sandpaper. this should be done every year before heating season.
Good luck
Mar 28, 2009 | Goodman GMS90703BXA Heater
Will not go into defrost
Did you change the thermostat in heat pump? or did you change it when you replaced the board?
Dec 06, 2008 | Goodman CLQ36AR49 Air Conditioner
My GOODMAN furnace GMH80703ANAA Starts but quits 5 seconds later
You have a flame sensor that may just need cleaning take out and take fine sand paper or emery cloth and clean
Nov 30, 2008 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
199 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
