Question about Canon MultiPASS MP370 All-In-One InkJet Printer
Mp370 nnot printing color even after changing ink tank
My step daughter ran the color tank completely empty and did not tell anyone, it was left this way for a couple of weeks, until I needed to print. That is when I realized that it was empty. I put in a new color tank but it would not print in color. So I changed both the black and color (2nd one for color) tanks and reset the levels.The black prints fine but there is no color printing. I have cleaned the cartridge and reinstalled, did a deep clean and a head alignment test page, but the color is still not printing. I have heard that soaking the print heads in warm water might help. This was a very good printer and I would like to keep it. Any help would be greatly appreciated.
  • 2 more comments
  • beatz74 Dec 08, 2008
    I have the same issue...almost. Green and yellow print, but the red doesn't. I tried the same things you did. Have you found a solution yet?
    Thank
    Shawn
  • rstrmn Dec 27, 2008
    my MP370 started printing white streaks when black printing. Tried deep cleaning - problem got worse; changed black tank twice - same result. Bought new print head - nothing at all in colour or black; exchanged print head at supplier, still nil in black or colour. I've only used genuine Canon inks throughout. Is there anything else I can try?
  • Anonymous Jan 15, 2009
    Looking everywhere to find an answer to this
  • Anonymous Feb 26, 2009
    My problem is similar but the black is not printing every line. It is missing a lot. I have changed the cartridge 3 times. I too like the printer and want to keep it.
Take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Posted on Mar 05, 2009
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
How do you remove the ink cartridges from the
To service the ink tanks:
Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
i_note_us.gif Note
If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2 Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3 Remove the ink tank whose lamp is flashing fast.
(1) Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Important
bullet_s.gif Handle ink tanks carefully to avoid staining clothing or the surrounding area.
bullet_s.gif Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
i_note_us.gif Note
Be sure to replace ink tanks one by one when replacing more than one ink tank.
4 Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
(1) Unpack the new ink tank and completely pull off the orange tape. Then, remove the film.
(2) Remove the orange protective cap from the bottom of the ink tank and discard it.
Important
bullet_s.gif Be sure to remove the clear film from the ink tank in the exact order shown in step 4-(1), as failure to follow this step may cause the ink to leak and stain your clothes and hands.
bullet_s.gif Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
bullet_s.gif Do not re-attach the protective cap once you have removed it.
bullet_s.gif Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
bullet_s.gif Ink on the removed protective cap may stain your clothes and hands.
bullet_s.gif Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5 Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the push_3.gif mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important
Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6 Close the Inner Cover.
i_note_us.gif Note
Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7 Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
i_note_us.gif Note
bullet_s.gif The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
bullet_s.gif To maintain optimal print quality, use an ink tank within six months of first use.
bullet_s.gif Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
bullet_s.gif Color ink consumption may occur even when black-and-white or gray scale printing is specified.
Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
bullet_s.gif When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Apr 03, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MX850. Print blank after ink changes. The black ink, PGBK-5, ran out so I replaced it with a cheap generic ink tank. But it didn't work, nothing print, not even color copy. I thought the ink is bad...
That is a common problem on all Canon printers, the purge assembly on the right where the printhead parks, has a pump inside and hoses that go to the filters and ink absorbers. When that unit goes out you need a replacement. A job best done in a shop. When the printhead is not cleaned and primed properly you get blank pages no matter how full the inks are.
Dec 24, 2009 | Canon PIXMA MX850 Multifunction Printer
Printer will only print in colour ink, not anything in black text
The issue your having is more then likely the ink cartridge itself or the printhead. Here is the steps in checking and possibly fixing the issue. Step 7 though should be done by a repair tech.
(1) Check that the orange cap or tap is not on the printhead.
(2) Remove the printhead and re-install it.
(3) Perform printhead cleaning, and visually check the test print for non-discharge of ink from nozzle.
(4) Perform head-refreshing, and visually check the test print for non-discharge of ink from nozzle.
(5) Replace the appropriate ink tank.
(6) Replace the printhead
(7) Replace the purge unit.
Jun 18, 2009 | Canon Office Equipment & Supplies
The ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Apr 01, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
MyHP Photosmart C5180 has stopped printing colors and all ink is
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Solution
Complete the following steps to resolve this issue.
Step one: Check the printin grayscale setting
If the self test page printed in color, the ink cartridgesare okay, and the ink levels are well above empty, the printer software hasprobably been set to print in grayscale. Follow the steps below to check thissetting:
  1. In the software application you are trying to print from, click File, then Print. The Print dialog opens.
  2. Make sure your printer is selected, then click Preferences. The printer Preferences dialog opens.
  3. Select the Color tab, then make sure that Print in grayscale is not selected.
  4. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved, you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved, continue to the next step.
Step two: Check the inkcartridges
NOTE:- HP cannot guarantee the quality or reliability of non-HPink.
  1. Check the ink cartridges to determine if they have been refilled. If they have been refilled, try replacing them with genuine HP ink cartridges.
  2. Try the print job again to see if this step resolved the issue. If the issue is not resolved, continue to the next step.
Step three: Check inklevels
Replace any empty print cartridges.
  1. Press Setup .
  2. Press clip_image001.gifto select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed.
Figure 1: Ink levels
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
  1. Try the print job again to see if this step resolved the issue. If the issue is not resolved , continue to the next step.
Step four: Service theproduct
If you have completed all the steps listed above and arestill experiencing a problem, service the product.
Nov 23, 2008 | HP Photosmart C5180 All-In-One InkJet...
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Feb 18, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
805 people viewed this question
old marine
old marine
