Question about Check Point Network Adapter
Cannot get my Bunker Hill Safe open.
The battery died. I have the keys but cannot figure out where the lock is.
  • 2 more comments
  • Anonymous Feb 19, 2009
    I never recieved a key for the safe and I have the same modle with the same problem please help
  • Anonymous May 11, 2009
    batteries died and dont have the key
  • CharleyF May 11, 2010
    Does anyone know where I can get duplicate keys for the Bunker Hill Digital Safe Model #45891. The safe is locked, the combination will not open the safe.
  • Jamie Sims Dec 13, 2017
    My husband motorcycle key opened ours lmao very secure...
Get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
Posted on May 19, 2009
Hi, I'm looking for keys to my Bunker Hill safe. Model # 91006. Please advise. Thank you. Al
Posted on Mar 04, 2009
On the manual for this safe it says "For Technical Questions and replacement parts, please call 1-800-444-3353.
Posted on Jan 18, 2009
Bunker safe how do u set digital code
Posted on May 02, 2010
    New Friend:
  • 3 Answers
On mine you gotta take the cover off where number pad at
Posted on Nov 29, 2008
    New Friend:
Behind the big sticker to the left of the turn dial
Posted on Apr 23, 2013
3 Suggested Answers
YaBaPortugal
  • 123 Answers
SOURCE: My Bunker hill safe Batteries died and the keys are inside.
Check this out:
http://www.fixya.com/support/t1062111-bunker_hill_safe
(no need to re-invent the wheel, other experts have given solutions first)
Posted on Sep 17, 2009
  • 3 Answers
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
How can I open my Bunker hill safe 95824 with a battery failure ?
Call harbor freight in CA and they'll let you know if there is a cure. They have an 8xx number for ordering parts and such, which is also their 'tech support' line.
Aug 15, 2014 | Computers & Internet
I have a bunker hill safe ,item# 91006,batteries too low,no key, drilled out overide lock,still won"t open, now what?
you can also get some wires feed him into the back contacting the battery terminals hold in there with a 9 Volt, four hands and patieance and then..... you get my drift. Worked for me! :) $
Dec 26, 2012 | Computers & Internet
I have a bunker hill safe #93575, the battery is getting low. is there any thing i need to know about changing the batterys
Change batteries ASAP because if your batteries die you will be unable to get into the safe without the key. The batteries are located inside the safe. If you can't open the safe, you can't replace the batteries!!!
There are NO replacement keys available for model #45891. We've tried. I would NOT buy this safe again for these reasons.!!!
Nov 08, 2011 | Check Point Network Adapter
My husband locked both keys in the safe 94985...
Search on "How to open a safe with a potato" and you'll find a youtube video on how to open that safe. All the Bunker Hill safes use the same lock mechanisms which have a critical design flaw if the spring on the solenoid is weak in that the plunger bounces enough to allow the bolt to be thrown open if you can time hitting the front of the safe just right. Of course, if you mount it such that you can't get a good swing in then no problem. There are two adjustment screws to the bolt throw, if your safe is easily opened this way, you might want to adjust these screws so that more of the plunger hits the stop. I couldn't get mine to open with a rubber mallet but it's mounted so you can't get a good swing in.
Jan 30, 2010 | Check Point Network Adapter
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
CANT UNLOCK BUNKER HILL BOOK SAFE
Battery died and i can't find the key or the instructions to open the safe
Sep 22, 2009 | Locks & Locksmithing
Check this out:
Sep 17, 2009 | Check Point Network Adapter
I have a bunker hill safe digital, and battery is too low to open the safe and cant find my key, probably inside, any suggestions
If you have the small electronic Bunker Hill safe with lost keys and dead batteries, this is a potential solution... Take a hammer and strike the top of the safe while attempting to open at the same time. You may need to place on object on top of the safe such as a flip flop shoe to strike with hammer to smooth out the pressure when striking. It should pop open after several attempts.
Jan 25, 2009 | Check Point Network Adapter
Bunker hill safe
Sep 20, 2008 | Check Point Network Adapter
Check Point Network Adapter Logo
6,349 people viewed this question
Top Check Point Computers & Internet Experts
DROPNDEAL
DROPNDEAL
Laxman Bisht
Laxman Bisht
Gil Shultz
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
