Question about Weather King 10AJA6001AH Air Conditioner
Defrost Cycle Problems
I live in North Fl;orida and I have a 5 year old WeatherKing Air to Air Heat Pump MODEL 10PJA4201 which works Great, Good Cold Air in summer, Good Heat in winter, Until it gets really Cold out side, then it hangs up in the Defrost cycle the out door condensing unit only humms and the fan doesn't rum. The indoor Air handler and heat strips runs and recycles the indoor air without any heat from the Heat Pump. I got up one night and monitored it and the unit remained hung up in the Defrost Cycle for 3 hours, until I bumped the thermostat down enough to shut off everything indoors and out doors, after waiting approx 2 minutes i bumped thermostat back up calling for heat, everything came on and ran fine the rest of the day, until the next Cold night and it happened again, What might the problem be?
  • 22 Answers
It is either the defrost thermostat or timer in the main board, best to replace both, and have charge checked.
Posted on Mar 06, 2013
  • 96 Answers
You need to replace the defrost board and sensor
Posted on Nov 22, 2008
I have a 5 year old heat pump (electric) Home is 5 years old and is very energy efficient with 6 inch outside walls. Do I have a problem as the air will run for 5 minutes and shut off for 5 minutes and...
One thing you might check is to make sure there is not cold air blowing across the thermostat from one of the vents. I've seen this many times make the thermostat short cycle.
Some less expensive thermostats may be programmed to short cycle. If you have instructions available for the thermostat, try to find information or the "heat anticipator". It may have an adjustable setting.
Jun 30, 2011 | Heating & Cooling
Fujitsu heatpump 13 years old is not heating room as it used to.filters are clean.i have gauges and would like to know what pressures are good and what pressures indicate low refrigerant or worn...
The refrigerant and compressor are related in cooling the room.As for heating problem the thermostat needs to be checked.
if you're used to a certain temperature of air and your heat pump is producing much cooler air, take the following steps. (Note that a heat pump may go into a defrost mode to prevent icing. When this happens, it can temporarily output cold air. Also be aware that the heat pump will have to work harder to produce heat.)
1) First be sure the thermostat is set properly. Try raising the set temperature 5 degrees F. and waiting a few minutes.
2) Be sure the room-heating registers are open.
3) Check the heat pump filter. If it's dirty, change it.
4) Be sure the auxiliary heating elements are working .
5) Clean the coils of the outdoor condensing unit.
If still the same problem then thermostat needs to be checked and replaced.
Thanks.
Jun 15, 2010 | Heating & Cooling
Tempstar heat pump: want to bypass defrost thermostat
Don't attempt to bypass defrost mode. If it's cold enough to use as a heat pump, it's cold enough to need the defrost cycle.
It sounds like a sensor issue, although it may be the controller board.
Unless you know how to work on equipment like this, I urge you to get a professional to service the unit for you.
Jan 22, 2009 | Heating & Cooling
Screaming Weatherking Heatpump!
If the scream is something new...have  tech look at it.  You've got problems coming and you don't want that on a really cold day.
Nov 23, 2008 | Weather King 10AJA1801AH Air Conditioner
Defrost Cycle Problems with Weatherking Heat Pump Model 10PJA4201
look for your diagram on the back of the door panel
Nov 22, 2008 | Heating & Cooling
Defrost Cycle Problems with Heat Pump
That's what a heat pump does. The problem to me sounds like you don't have a big enough heater inside.
Apr 30, 2017 | Weather King 10AJA4201AH Air Conditioner
Heat pump condinser freezing.
YOU HAVE ONE OF SEVERAL PROBLEMS , FIRST AND EASIEST TO REPAIR KEEP FILTERS CLEAN REPLACE EVERY 30 DAYS , #2 LOW CHARGE WILL CAUSE ICE ,# 3 A FAULTY INTERMITTENT FAN CONTROL SWITCH ,THIS WOULD BE MY # 1 GUESS SINCE I HAVE SEEN IT MANY TIME OVER THE YEARS , #3 WOULD BE A FAULTY DEFROST CONTROL BOARD OR SENSOR , THE REASON I LEAN TOWARD THE FAN CONTROL IS YOU SAY THE ICE IS ALSO IN THE INSIDE UNIT AND THIS IS MOST COMMON WITH RESTRICTED AIR FLOW OVER COILS AND SOME TIMES THE FAN SWITCH WILL CAUSE THIS PROBLEM THE DISCHARGE TEMPERATURE IS DIRECTLY RELATED TO THE TYPE OF UNIT ,TYPE OF REFRIGERANT IN SYSTEM AIR BALANCE CFM OF FLOW MANY VARIABLES IN THIS EQUATION,CANT SAY
Dec 20, 2007 | Ruud UAMB Air Conditioner
Weather King 10AJA6001AH Air Conditioner Logo
259 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
