Question about Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Makita DSC520i chainsaw will not start... not a pop.
New plug, getting spark. New gas, vapor expelling from cylinder with plug out so must be getting there. Always run gas dry when not going to use for awhile. Haven't used about six months. Never happened before, always starts on third to sixth pull. Yes, switch is set to on.
Never have touched high/low throttle settings.
What am I missing here? How to get the saw running???
  • 1 more comment
  • mikemoyers Nov 22, 2008
    Original request stated... new plug and getting spark. Answer... clean the plug doesn't get it.
    Please try again.
  • mikemoyers Nov 23, 2008
    Carburetor filter cleaned. H, L, S settings reset according to owner manual specs. Still no go.
    Spark fires great. Must not be getting gas. New gas in tank. No kinks in gas line.
    Now what?? Never had any problem with this saw starting for years. Suggestions???
  • mikemoyers Nov 26, 2008
    Compression ok. Never leave saw sitting with gas in it. Followed all suggestions, still no start.
    I give up.
    Found a saw shop near here that will work on Makita. Took it there.
  • 19,396 Answers
Check that the gas is getting to the engine, check that the high low carburetor setting had not gone bad because of the vibrations, you will probably need to adjust settings again.
The carburetor should also have a filter that you need to check up, if it is obstructed you do not get fuel into the engine.
Posted on Nov 21, 2008
  • Ginko
    Ginko Nov 26, 2008
    Sometimes you need to take apart the engine and clean all carb parts soaking them in gasoline, if you want a new chainsaw check the following choice, you can also buy online: chainsaw
    Scholar:
  • 174 Answers
I think you may need to pull the air cleaner sponge out and
add a little fuel in the air intake....to prime it.....there is a pin
that needs fuel to float.......I always have to do this with mine
when it has not been used for a while.
Good Luck
Posted on Nov 26, 2008
    Scholar:
  • 126 Answers
Have you checked the choke assembly? Make sure th choke is not staying closed on you.
Posted on Nov 23, 2008
  • Slick54 Nov 23, 2008
    Guru:
  • 674 Answers
Hello
there are alot of good ideas here .
we have seen very poor gasoline these days and the fuel will go bad in the carb.
i dont know why but if you try to start this engine with this bad fuel it fuel foules the spark plug.
and i have tried to clean a spark plug and it will look like it sparks fine . but take it from me it wont fire under compression. so my advice is once you are sure you have all the old fuel out of the system you need to pull over the engine with the spark plug out many times to clear the chamber.
now install your NEW spark plug and start as usual.
good luck
later paul
Posted on Nov 22, 2008
    Sergeant:
  • 229 Answers
I had a saw that did this to us when we would try to use it after a long summer season. We would simply give it a shot of starter fluid to get the works going and after the first use of the season it would always start after that. Should help be careful with starter fluid small motors don't need as much as larger ones of course, just a short spray or two usually worked. Good Luck
    Brigadier General:
  • 6,966 Answers
Initially and since it is a 2stroke engine, pls try:
  • change plugs, even if clean & with spark;
  • make sure the there is no stale 2T oil in the bowl//bottom of the carb and inside the compression chamber. Pls remember that the bottom area where the piston goes down to is also part of the combustion. You can use fuel to clean and air dry or use a compressor. This is specially true for the bottom half of the combustion chamber;
  • pls make sure that the exhaust is not restricted/clogged.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • 76 Answers
This is a fuel blockage issue clearly.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
If it had fuel at one time in the carburetor before it sat it has probably "varnished." You'll have to remove and clean the carburetor. These little engines also use a diaphram system in the carb to pump the fuel. They can become hardened over time. Same fix, except re-assemble with a new carb rebuilt kit. Its easy if you have basic mechanical skills.
thanks
good luck
  • 4,806 Answers
Possible engine flush and oil change required caused by running the engine dry, takes in air/dirt through intakes causes airlocks so you get fuel starvation end engine cuts out or splutters
hope this hepls
regards
  • 5 more comments
  • Lee Hodgson
    Lee Hodgson Nov 22, 2008
    use some contact spray (WD40) on the engine to repel any moisture and loosen certain parts, especially around the rip cord area! clean the fuel jets and pump and make sure it is pumping gas, if you find that the rip cord is easy to pull and it shouldn't be, there could be a casget seal broken resulting in loss of pressure to the engine
    hope this works
  • Lee Hodgson
    yes an "engine flush" might work as i suggested earlier
  • Lee Hodgson
    check the HT lead that goes from the spark plug engine for continuity, it may be this which is the defective part
  • Lee Hodgson
    also a soda bottle top of gas into the carburetor, that usually give them a kick :)
  • Lee Hodgson
    Lee Hodgson Nov 26, 2008
    strip the engine down, lean it propery, reasaemble the engine and fill it with oil and clean fuel
    good luck and regards
  • Lee Hodgson
    did the matika repair shop solve the problem?
  • Lee Hodgson
    of course the engine may have seized or the piston has cracked causing the engine to loose pressure, so it will not start at all
    regards
    Genius:
  • 1,142 Answers
You need to clean the plug as it might have been accumulated with carbon monoxide
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
Nov 11, 2015 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Why will my saw not start, good spark new plug fresh gas
Sounds to me like a plugged up fuel line or old fuel in the fuel line. You may be able to clear it by spraying some starting fluid into the carb to pull the old fuel through. You only want to do this 2 times because this has no oil in it. Another suggestion it to remove the spark plug and put some of your fresh fuel mix directly into the chamber. About an eyedropper full should work.
Jul 13, 2015 | Makita DCS6401 20 20",64cc Chainsaw 2...
Dolmar ps 34 or makita dcs34
Replace the spark plug and get some starter fluid. Add FRESH gas/oil mix. Spray a couple squirts in the spark plug hole, replace the spark plug and try to start it. I would add Sea Foam (get it at any parts store) to the gas tank and let it run for ten minutes. Go to the manufacturers website, support, and search for your saw by model/serial number.
Mar 15, 2014 | Garden
Makita dcs340 will not start, spark plug is sparking but when placed back into the cylinder it does not fire.
Spray some starting fluid in the carb because it may not be getting fuel. If it fires the fuel may be bad. If the fuel is more than 2 months old dump it out and put in fresh fuel.
Oct 03, 2013 | Garden
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
New makita chainsaw difficult to start. Any suggestions?
sue fresh 2 stoke fuel and buy a new spark plug
Aug 05, 2009 | Makita Garden
Petrol chainsaw wouldn't start, and with trying to get it running the pull cord is very very stiff to pull out and it is now just jurking small sections of the cord out at a time and still will not start
Sounds like it may have hydraulic lock--the upper cylinder is full of fuel. Remove the spark plug and pull the engine through a number of times. Make sure the ignition switch is off--it might ignite the expelled fuel. You may find that the crankcase is also full of fuel--continue to pull the starter until there is no raw fuel expelled. Now, why didn't it fire! Probable bad ignition system--check for firing of a clean spark plug (ignition on). If ok, try the original plug, it may need to be cleaned or replaced.
Jun 27, 2009 | Garden
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Makita DCS51018 18" 45cc Chain Saw 2 Cycle Logo
1,139 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
