Question about Datalogic DL9600 Viper RF (942804129) Portable Terminal
0 characters
1 Points
If the touch screen wont light up on a falcon 4220 does that mean the touch screen itself is bad?
Nov 19, 2014 | Datalogic PSC Falcon 4220 Data collection...
Why position fault code 14.113 for atamaxI4308?
Good Day
Position faults are usually caused due to either a dirty or uncalibrated media sensor.
Make sure the correct sensor type is selected under MENU MODE / MEDIA SETTINGS / SENSOR TYPE.
Media sensor is usually green in color, on top will be a white line or arrow indicating where the sensor is located. Inspect the gap between the upper and lower pieces of the sensor to see if there is any dirt buildup or pieces of labels stuck inside, try cleaning the gap with isopropyl alcohol. In case there are labels stuck and you cant get it out, you will have to remove the sensor and take it apart. Just be careful when doing so as the plastic can break very easily.
What you also can try is to re-calibrate the media sensor, switch the printer off, hold down the feed button while switching it back on and booted up until it starts feeding the labels.
You can also do a Manual calibration through MENU MODE / MEDIA SETTINGS / SENSOR CALIBRATION and select STANDARD CALIBRATION and follow the on screen prompts.
Hope this helps, good luck.
Sep 03, 2014 | Datamax I4308 PRINTER 4 Inch DIRECT...
I need to know how to clear and format to new out of the box it is a MC3090 motorola Symbol because it doesn't have enough memory and it doesn't save many codes thank you
1. Press and simultaneously hold the 1, 9 and Power keys. Do not hold down any other keys or buttons. As the mobile computer
initializes, the Symbol splash window appears for about a minute.
2. Calibrate the touch screen. See Calibration Screen to calibrate the mobile computer screen.
Hope this helps,
Sep 12, 2011 | Barcode Scanners
I have a Datalogic Viper 9600/RF-3. The barcode reader boot in dos, not in windows, How I can install windows? I haven't communication cable. Can you help me, please? Thanks PD. Sorry my english.
Sorry to say its not possible to change the OS to windows. but i do have some's which are windows based. i could sell you. PM me for details.
Jul 12, 2011 | Datalogic DL9600 Viper RF (942804129)...
Ls2208 Barcode Scanner program for .NET
here is the Barcode Scanner Program right now, it seems like being able to scan barcode with Symbol Ls2208 handheld device.
if it is not workiing, go to this barcode website to find more compatible software for Ls2208, i am sure you will find the proper one.
NET Barcode Reader Barcode Reader ASP NET Barcode Reader VB NET Barcode... Barcode Components NET Barcode Generator Reader Java Barcode Generator...
Jul 28, 2010 | Symbol LS2208 Handheld
I have a Window 2000 computer that has a Radeon 7500 series 64MB graphcis card in...when I color calibrate with Gregtag MacBeth eye1 puck, it seems to hold the calibration but when the computer restarts...
yeah,.. your pc isnt saving the settings..
1 out of 2 reasons..
1.) the software Gregtag MacBeth needs reinstalling.. For some reason the ini or registery isnt loading propperly..or isnt saving propperly.. chect the settings and save them as the default settings in the application.. (its been soooooo long since i used it I cant walk you through it.. but thats one of the cause)
2.) the computers registery is messed up,, YOu can try a registery program such as tune up utilities or system mechanic.. If that fails you need to wipe the os iut and reinstall it..
Its one of those above..
Mar 13, 2010 | Barcode Scanners
Error 5 for ncr 7875 scale scanner
If the scanner read only two times is a problem with the communication protocol.
What protocol do you use?
Explain more about your problem with your calibration pricedure
Jul 29, 2008 | NCR 7875
Align Screen
It will need a new screen. This is a common fault on this type of terminal and since the touch pannel is incorporater on the screen assembly, that is the only solution.
You could always try a software update from IPL mode, however is not very likely that it will resolve the calibration issue.
Jul 23, 2008 | Symbol PPT 8800 Wireless Barcode Scanner
Well regarding this error sending you this display of the scanner in most cases is needed because if the scanner calibration, you have to do is:
Remove the dish from scanner (where you put the products to weigh), there you will see that has a plastic part on the right side, and take away that the bottom is a black button color you need to start to put pressure gauge.
Once you press this button, and is ready to start calibrating, then put him back to the plate and the scanner with a voice that sends you will be asking some weight, so this should have on hand your weights to calibrate the scale.
First the scanner asks 0 kg. in this step not going to put anything in weight, ahi press the button Scale Zero appearing in the panel's scanner,
After asks you to 2.5 kg, is there when you need to put the 2.5 kg asks you, when you have them placed on the plate press Scale Zero, the scanner then will ask now that you put 5kg, then you take away those who had 2.5kg and you put the 5kg, and when you have 5kg in the dish press the button Scale Zero, now the scanner will ask that you put 10k, then take away the 5kg and that he had put the 10k that asks you to press the button and Scale Zero, and finally asks you to the scanner in this 0Kg, then you take away the 10k and leave it with nothing, and press Scale Zero
If the calibration did well Scanner you send a voice message that says Calibration Complet or calbración completed, it is very important that when you calibrating the scanner is not moving or having obstacles that may make the calibration is not made well, good clean plate and that this part of the bottom, which revises the 4 Gomito that has to sustain the plate are complete, that are not broken up or are some more than others and that when you put the dish did not move. fijate also not hit the plate or the chassis of the scanner with something else, so there's no obstacles in the calibration,
If you salio calibration is not well in the display will show a 9Error, this means that there was interference during calibration, it is required to check well before the scanner or do a cleanup.
Feb 21, 2008 | NCR 7875
Not connecting to host
I think the default password is "degibkdr"
Sep 05, 2007 | Datalogic DL9600 Viper RF (942804129)...
Datalogic DL9600 Viper RF (942804129) Portable Terminal Logo
46 people viewed this question
Top Datalogic Barcode Scanners Experts
Gareth Cockram
Gareth Cockram
Paul Bade
Mister Danger
Are you a Datalogic Barcode Scanner Expert? Answer questions, earn points and help others
