Home | Hotpoint | 24 in. HDA2000Z Built-in Dishwasher | Dish washer does not pum...
Hotpoint 24 in. HDA2000Z Built-in Dishwasher
Problem for Hotpoint 24 in. HDA2000Z Built-in Dishwasher
Dish washer does not pump out water after rinse or wash
By emissionwiz on Nov 21, 2008
Pump works and water sprays from nozzels, but the system does not pump out, the hose to the garbage disposal is clear and the screen is clear in the bottom of the washer, Solenoid issue?
Comments:
Nov 21, 2008
- What could this be?
Best Solution
posted on Nov 23, 2008
Helpful)
anthonybuzzo
Rank: Guide
Rating: 81%, 4 votes
Check flap valve and solenoid-Check for hose kinks or food clogs-Check pump impeller for damage-Check-timer Check the (check-valve flapper) some models have a check valve located where the drain hose attaches to the dishwasher.If you just installed an garbage disposal check the knock-out plug at the connection.Check that the pump hasnt gotton stuck due to lack of use or gunk in the pump. 3 things 1-You can remove the lower kick panel and turn the fan blade on the motor until it turns freely 2- Boil a big pot of water and pour it into the tub part let it stand for 15 to 20 min then try the dishwasher 3- Or my (FAV) duct tape your shop-vac to the waste hose and try to blow or **** out the stoppage. Rice is a big problem and pasta for dishwashers and thanks for the advice on my car I will try the method,and sorry about the comment
Was this helpful?
Yes
No
Solution #2
posted on Jul 15, 2009
Not Rated)
docwho82
Rank: Guide
Rating: 80%, 3 votes
I had a similar problem with my dishwasher, I don't use it very often, but some time ago I change out my garbage disposal with a new one because the old one burnt out. As it turned out when I did finial decide to use the dish washer it would not drain in either cycle. When I check out the dish washer I disconnected it from everything to pull it out of the place so I can check to see if the pump was working so, I pulled it out and plug it back up and turned it on with the hose that connects to the garbage disposal hanging over the sink, as it turns out it drained just fine, when I went to hook it back up the proper way I check out the garbage disposal and found that there was no hole where the hose from the dis washer was supposed to connect to. Check to see if you have a hole for one and two see if it is clogged.
Was this helpful?
Yes
No
Popular Solutions for Hotpoint 24 in. HDA2000Z
Questions and Unsolved Problems for Hotpoint 24 in. HDA2000Z
Do you recommend Hotpoint 24 in. HDA2000Z Built-in Dishwasher?
Answer
Answer
When turned on the cycle does not begin water collects at the bottom of the washer
Answer
wash cycles not working, load machine, select wash cycle, it then runs but does not clean
Answer
will not wash- not sure if it is the same model, but i turn it on to wash, and it doesnt start a... (More)
Answer
when i turn the dishwasher on the water comes in and it sounds like it is washing but when i open... (More)
Answer
My hotpoint dishwasher leaks every time it starts to drain the water.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA2000Z...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
