Question about Reebok RL1500 Elliptical
Lost cookbook for Little Chief smoker
Need recipies
  • llott2 May 02, 2009
    no instructions or recipes with my little chief smoker
    President:
  • 1,734 Answers
Check here, they will get the manual for you.
Posted on Jul 15, 2009
I need a new electric heating element for my Little Chief smoker
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=Little+chief+replacement+element&rh=n%3A3375251%2Ck%3ALittle+chief+replacement+element Here is one source....
Jan 15, 2013 | Grilling
Bought little chief model 20 smoker don't know how to use it...
The Little Chief smoker, manufactured by Smokehouse, is available in front-loading and top-loading styles. Both models are electric, depending on a 250 W electric heating element to supply the heat. The smokers can accommodate a maximum of 25 lb. of meat or fish. These smokers are for outdoor use only, and plug into a 120 V AC electrical outlet.
  1. Brining
    • For extra flavor, treat your meat, poultry or fish to a brine bath before smoking. Use 1 cup of kosher salt for each gallon of water. Consider adding molasses, spices or even a pureed jalapeno pepper or two into the brine solution. Leave thicker pieces of meat in the brine solution overnight. Fish only need to be soaked in brine for around four hours.
    Wood Chips
    • Mesquite and hickory are probably the two most widely used woods for smoking, but apple and pecan wood can give your smoked foods another tasty dimension. As with anything else, experiment to create your own favorites.
      Smoker wood is sold either as chips or chunks. Use large chunks to smoke thicker pieces of meat; the chips will be spent before they have thoroughly smoked the meat. You can continually replenish the chips, perhaps every half hour, for as long as you wish to smoke the food, but the job can be tedious with a large roast that takes hours to smoke.
      Smoke the wood well before it is introduced to the heat. Chips will be completely soaked in a half hour, but chunks of wood will require an overnight soaking before use.
    Smoking
    • When your meat is thoroughly brined, and the wood soaked, carefully lay out the meat on the smoking racks. Make sure that there is some space between each piece. Place fish on the rack with the skin-side down. Drain your wood and place it into the smoker on top of the heating element. Use the small pot that is provided to keep moisture or collect juices. Place the racks into the smoker and close up the box. Plug in the electrical cord and within about 10 minutes, you should see smoke gently trickling out from the smoker's vents. The thicker the food inside the smoker, the longer the process will take.
    Mar 18, 2011 | Luhr Jensen Little Chief 9800
    Should you soak your wood chips in water before using them in a little chief smoker?
    yes its a good idea to give them about an hour,
    at this time i ususally put a lil extra seasoning in the wood like beer, soy, wistachire
    use your imaginiation
    Oct 04, 2009 | Luhr Jensen Little Chief 9800
    I have a little chief 9800 top load smoker and lost the heating element in a move. There are two elements available, a 7.5" and an 8.5", but I'm not sure which size my smoker takes. Is there any way to...
    The #4 Little Chief element is 7 inches and more importantly is 250 watts, this is the correct wattage for ALL Little Chief Smokers newer than about 15 - 20 years old.
    The #5 Little Chief element is 8.5 inches and is also 250W but is for newer models before 2006.
    Look at www.smokehouseproducts.com for clarification & best fit.
    For very, very old models (20+) there is a ceramic disk (175W) that heats the chip pan and is hard to find and expensive, a person would be better off finding a new one on sale at the big box boys store
    Jul 07, 2009 | Luhr Jensen Little Chief 9800
    My little chief smoker never got the fish I was smoking to 140 deg.I had this unit smoking for two & half hrs. is this normal?
    How old is the smoker? Is the heat element old, weak (maybe needs replacing?) Did you save the cardboard box the smoker unit comes in and place it over the smoker for the actual smoking process? This is recommended by the manufacturer and keeps the smoke and heat in, and gets you up to temperature. see also www.smokehouseproducts.com
    Jul 02, 2009 | Luhr Jensen Little Chief 9800
    Lil Chief Smoker trips GFI plug
    There is a short somewhere in the unit. Return it ASAP!
    Jun 25, 2009 | Luhr Jensen Little Chief 9800
    Reebok RL1500 Elliptical Logo
    550 people viewed this question
    Top Reebok Sport & Outdoor - Others Experts
    michael
    michael
    Marvin
    Marvin
    ray gallant
    Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
