Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
No suction or very little
My model number is actually U6425-900 but that doesn't come up in search....there doesn't seem to be any suction under the vacumn...when I disconnect the hose there is some suction..the hose that is curved and goes to the bottom of vacumn appeared to be clogged so I cleared that with a flexible brush but still no suction....can you help?
thanks
jennie
    Scholar:
  • 55 Answers
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Posted on Nov 21, 2008
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
Beater bar not working - no variable suction
Take it to your local vac shop for repair. Depending on what model you have, it may have a bad switch or you brushroll ends could have failed. Both are common issues.
Aug 08, 2017 | Dyson Vacuums
Our Dyson Animal DC28 is not transferring the suction from the wand to the floor. After turning on the unit, suction can be felt at the top of the handle wand. Once the unit is leaned to vacuum the...
Sorry to hear you're having difficulties with your DC28. If it doesn't seem to be picking up as well as usual, it's possible that there's a blockage in the system, and you may need to give the filters a wash. The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1231&product=DC28-ANIMAL
The correct way to wash the filters is shown in the video below. Under normal use, this should be done at least once every 3-6 months. Use cold water without any detergents, and ensure the filters are totally dry before replacing them - this may take up to 24 hours.
http://www.dyson.com/support/help.asp?article=1456&product=DC28-ANIMAL
Hopefully, by clearing any obstructions and washing the filters, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Dyson Online Customer Support
Aug 28, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
The suction seems so strong on the floor that it is suddenly hard to push. Don't notice anything thing that would actually lift it off the ground making the suction not so air tight. I have check the...
I'm sorry to hear you're having difficulty using your DC24 on this particular flooring. The cleaner head is designed to adjust automatically to suit the surface being cleaned, and the cleaner's powerful suction causes the soleplate to seal closely with the flooring for high pick-up of dirt and debris. You may find on certain floor types that this makes the cleaner feel a little heavy to push.
Reassuringly, it sounds as if your cleaner is working correctly - however, if you wish to discuss your issue further with one of our experts, please get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Jul 17, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My 88 year old mother bought a Dirt Devel DHC001 - has been used twice but it looks blocked and has no suction but there is suction at the pipe end if I take it off. I have opened the red end and emptied...
to answer this properly, I am going to need the actual model number on the bottom of the unit on the silver/metallic sticker. Usually MO###### If you can get that I can help you out further.
Mark
Nov 06, 2010 | Vacuums
Very little suction in hose no tears in hose
Hi there, SmartAlec from NelsonVacuums.com.au . I have fixed hundreds of Dyson DC07 vacuum cleaners over the last few years and i would say there are 2 possible causes for the loss of suction.
1st is that the filter looks clean but is actually worn anyway. The way to tell is remove the washable filter from your vacuum cleaner. Take out the foam insert this seems to last longer that the other part. Hold up the plastic cage to the light and look at the white part (well it used to be white anyway) you should be able to see light through it. If you cant see through it you need to replace it. Here is a link to that filter for purchase . To verify this is the problem just run the vacuum without the filter in you should see an improvement - note do not actually **** up material the filter is there for a good reason.
2nd problem is that you have a blockage in your radix assembly. If you take off the whole dirt bin and feel the suction on the upright part where the chamber joins the vacuum (basically bypassing the radix) if there is good suction here you will either need to replace the cyclone top or dismantle and clean it. (it is very difficult to clean as it doesn't completely dissassemble)
Hope this helps - If you want more help send me a message
HAPPY VACUUMING ! :)
Aug 24, 2009 | Dyson Vacuums
Very little suction? Someone give me an answer please.
You must have something obstructing the airflow. There is sometimes a small trap door under the vacuum where the brush is located. Open that door and see if there is something jammed in it. If you don't have the door, then there is an obstruction somewhere in the vacuum. You should also look in the hose.
Jim
Jun 10, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Low Suction When Using the hoses on the Dyson Animal
there is a washable filter either on the side of the motor or in the dust cup clean it out using water make sure it is dry before reinstalling also check for clogs there are several pices that are removeable the peice under the hose and vent clip? on the side remove and check for clogs
May 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
267 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
