My computer is running very slow, and it keeps freezing to the point where i have to shut it down, and restart, and it takes a long time to boot back up, can you help me
  • P. Thomas
    P. Thomas May 11, 2010
    sounds like maybe the memory and cpu are out of balance..do you know how to open task manager?
  • 60 Answers
Hi can you defrag the hard drive by right clicking on the disk and going to properties then tools then defrag
cheers
Posted on Dec 05, 2008
My laptop shuts down during bootup
Which point in the boot up is that? are there any error messages? Can you still boot to safe mode without any problem? Please answer my questions so that I can provide you with a detailed troubleshooting steps.
David
Jul 11, 2013 | Computers & Internet
Tip
How to run Check Disk in Windows 7 Below is the steps on how to run Check Disk...
Below is the steps on how to run Check Disk in Windows 7. From time to time if you are computer is not running properly this is important to run on your computer. The reason it time to time you will get corrupt files and/or files that left over from old installs that are slowing down the computer. This command will repair the files it can and remove the old unneeded files.
1. Open My Computer
2. Next right click and select Properties on the drive that you need to run Disk Cleanup.
3. Next click on the Check Now.
4. Next make sure that both options are check and click on the Start button.
5. Next click on Schedule disk check. The reason for this is if part is that if the sector is being accessed the sector can not be recovered. So this is ran before Windows fully loads.
6. Next click Start then click on the arrow next to the Shut Down button to get the Restart option to restart your computer. Note before you restart your computer you will want to make sure you have closed all your running programs.
At this point your computer will restart and run the Check Disk. Note this can run for over a hour depending how large the hard drive is.
After Check Disk is done running your computer will boot into Windows ready for you to use.
Next it is recommended that you run defrag on your hard drive this will take care of any fragmented files and put them back together. This as well will make your computer run a bit faster. This link will show you how to defrag your hard drive.
How to defrag your hard drive in Windows 7
on Oct 17, 2010 | Computers & Internet
Why does my computer take so long to restart?
There are SO Many possible factors causing slowdowns.
Start with checking the free space on your hard drive. You need some wiggle room to navigate and 25% free is recommended.
Defragment your hard drive. (I like the free Defraggler software better than Windows on feature.) this will take some time so run it overnight.
You may have background programs running. You do not need this--they will kick in when needed, and really slow you down.
For WIN 7 & Vista click Start and type in <msconfig> without the hentrax to bring up the System configuration window.
Click on Startup and uncheck everything except your antivirus (and something like SKYPE if you want it to kick in when you boot up). Apply, OK and Reboot. Check the box on the little window that appears i order to make it gone.
See if your fans are clogged with dust. It is very important to stick a pencil or something between the blades when spraying canned air to keep them from spinning.
Doing some or all of these should give you lightning speed! Hope this helps.
Apr 18, 2013 | Toshiba Satellite L755-S5158 Laptop
I need help with ibm thinkpadr40 have no idea what is going on tried somethings, blue screen keeps coming up and freezes and runs slow
If you are getting different problems at different times, they you have to start handling things slowly to exactly pin point the issue. It will be great if you can also document the error messages, when you get it, the windows version you are using etc so we can provide you more accurate steps and identify the exact issue.
First if you are using windows XP restart the computer in safe mode and try using it (if you wanted to use internet - wired) then restart the computer in safe mode networking.
Procedure to restart computer in safe mode:
Restart computer, keep tapping F8 key on the keyboard, instead of going to windows it will show up a windows advanced boot menu, where you need to use your up or down arrow key to navigate the control to Safe mode / safe mode with networking and hit enter key. this will show some commands / text on your screen and take you to safe mode.
Try using your computer in safe mode and see if your computer is giving you any error or if it freezes. If it does not give you any trouble in this mode then you computer is good, it should be the additional programs running in the normal mode that is creating the issue. we need to diagnose further to find it.
If it is freezing / gives your error message in safe mode itself, then there should be a problem with the hardware of your computer, we have to find out by eliminating the hardware one by one.
Do not worry, we can work together pin point the issue and we will help you to resolve this issue.
Dec 10, 2010 | IBM ThinkPad R40 2722 Notebook
My computer is slow and freezes all the time and also occasionally blue screen comes up
HP Compaq notebook will not boot up. It seems to start and immediately shuts down. I am unable to turn it off without removing the battery or disconnecting the power supply. This happened before and...
information. hpweb_1-2_plus.gifhpweb_1-2_minus.gifRun a Microsoft system restore
    hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows XP Click Start , All Programs , Accessories , System Tools , System Restore . Select a windows restore point from a time when the computer operated properly, and then restart the computer. hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows Vista or Windows 7 Click Start, type restore in the search field, and select System Restore from the list. Select a windows restore point from a time when the computer operated properly, and then restart the computer.
If the computer does not boot into Windows, you can restore the computer settings to an earlier point in time. Turn on the power and press f8 . On the Windows Advanced Boot Option screen, select Safe Mode and boot into Windows. hpweb_1-2_plus.gifhpweb_1-2_minus.gifUpdate Windows, the BIOS, and HP device drivers
Nov 11, 2010 | HP Compaq nx9600 Notebook
Gets hot and turns off
you are frying the computer. get a cooling pad they are a cheap way to keep the computer cool. games require more juice to run, so when you play them your computer is in overdrive trying to keep up and to cool down. if you keep it cool then it won't have to work as hard. the computer has a partition on the hard drive you have to press F10 or F11 key and it will boot off that. that is a restore partition, so you can take it back to the state in which you bought it.
Sep 30, 2009 | HP Pavilion dv6000z Notebook
1) Start up sometimes freezes, 2) Is not recognizing outlet power
Hi.
i recommend You in this Case to format and install a new OS
Windowns XP.
good luck
Dec 12, 2008 | Acer Aspire 3002LCi Notebook
Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Mar 19, 2008 | HP XW6000 PC Desktop
IBM T23 Freezes
have you tryed update on the bios ?
i had the same problem with a toshiba lap top
and a bios update solved it
Nov 04, 2007 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
David Payne
David Payne
