Question about Abit ST6 Motherboard
Abit st6 raid motherboard just beeps . doesn't boot BIOS
  • Mike Peluso
    Mike Peluso May 11, 2010
    Hi them_2006, could you include how many beep / long / short / repeating?
    When a system beeps more than once usually it is because of either, the memory is not seated correctly & or the graphics card is not seated correctly. Both or either (if so) will not allow display.
    So power down your system, unplug the power cord. Remove your memory, clean the copper on each DIMM with a drop or two of alcohol onto a cotton swab. Wipe both sides of each memory sticks. Make sure the memory is dry before reseating. (If you do have 2 DIMMS install only one DIMM into slot 1). Do the same for your graphics card (If you have one installed). Use caned air if you have some & blow out both, memory & graphics slots. Check all connections to devices before closing up your case. Re-connect the power cord to the PC & try booting the system. If you get display, great. Shut down the system & add the second DIMM (If you have one).
    Give this a try. Post back if this has not allowed the system to stop beeping.
    Good luck them_2006!
    Mike
  • 31 Answers
Hello
the beeps comes from motherboard are due to ram which is not properly inserted
so try to remove ram while pc is off and insert ram again
Posted on Nov 28, 2008
How do i connect the plugs
Here You can download manual: http://www.motherboards.org/files/manuals/2/st6.pdf,
in PDF file format; for connection, see page 8
Aug 06, 2013 | Abit ST6 Motherboard
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
I picked up a discarded complete computer with Abit AS8-V motherboard and standard CPU. The entire assembly had been immersed in floodwater. After cleaning, drying, and waiting a few days I powered it up....
Simple test: disconnect the hard drive and the optical unit and try to boot in BIOS. If you can't then the first thing you should check is the memory, followed by the processor. If you can then the hard drive is dead.
Mar 13, 2010 | Abit : AS8-V...
This motherboard is limited to 512Mb memory - is there a way to upgrade to allow more? ABIT-ST6
Sorry but this type of old motherboard has a limitation of having a 512MB of RAM as the maximum so there will be no way of upgrading it to a higher RAM, the best option that you can do is to change the motherboard to a new one....
Jul 31, 2009 | Abit ST6 Motherboard
LED on abit ST6
every motherboard should have a led light always on to indicate that there if power in it. the problem with system rebooting has to do with the ram or processor, since you said it does not recognize the hdd at times that means that the ram is working abnormally i.e it is week, u know ram means random access memory, so change the ram and make sure u get the right ram for your system
Jul 11, 2009 | Abit ST6 Motherboard
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Abit th7raid motherboard-160GB HD cannot recognize-needs flashing-out of my depth!
Hi coonster,
Abit TH7 Raid driver.
Windows inability to see all of your hard disk drive is not a motherboard issue.
It’s a windows issue. ( I suggest you use the hard disk drive software from the manufacture’s web site). Most allow you to download software that allows you to create a bootable floppy disk. Boot to this disk & setup the drive in a dos like window.
Once completed you can now boot to the windows CD. Do not allow windows to format
the drive.
That is what the manufactures disk will do for you. Install windows & please update it fully. Windows should see all of the 160GB after updating.
If you feel you need to update the bios, feel free to do so.
Follow Abit’s instructions on how to update the bios from this link;
http://fae.abit.com.tw/eng/download/bios/index_old.htm#486
If you have never downloaded a bios file or drivers from this site it can be a bit confusing. You’ll need to high-light the entire link below, than right click once to open the pop-up window. Than left click copy. Open internet explorer. Right click once in the address window & left click past. Than press the enter key on your keyboard. The site has a timer on the left side of the page. You’ll have to wait for it to reach zero.
Than a yellow bar will open across the top of the page that says, (To help protect your security, Internet Explorer blocked this site from downloading files to your computer. Click here for options...). Right click once on the yellow bar & left click download file. Create a folder on your desktop & name the folder " Drivers". Download the file named " infinst_enu.zip" into the driver folder. Us any uncompressing program & uncompress the file keeping the files within the driver folder. The action of uncompressing the *.zip file will create another folder named " Disk1".
http://www.nodevice.com/driver/download.html
To download the Abit TH7 Raid bios is done like the instructions above. For this bios file you’ll need to do the same with the link below;
Abit TH7 Raid bios file name " th736.exe ".
http://www.updrivers.com/getbios/Motherboard/Abit/TH7-Raid-BIOS/6187.html
Please retype verification code: "enter code listed on site".
Press enter.
Again create a folder on your desktop & name it Abit bios.
You will not find any drivers, bios or manuals directly from Abit. They no longer support this motherboard.
Mike
Nov 07, 2008 | Abit KT7A-RAID Motherboard
Abit ST6 Motherboard Logo
428 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
