Question about Toro Electric Ultra Blower/Vac 12 Amp
I need instructions for using my Toro vacuum/ mulcher attachments
I've been using the leaf blower, but don't know how to attach the vacuum and mulcher. The instructions are lost and I haven't ever used these attachments. Please advise.
    Problem Solver:
  • 5 Answers
Mine is a Black & Decker so I don't know if this will help. On mine there is one release button near the top of the handle. You press that down to release and remove either the blower tube or the vacuum bag assembly, whichever is currently on -- you can't have both! Then you engage the attachment you want to put on into a pivot at the bottom of the handle assembly, press the release button and engage the attachment at the top.
Posted on Nov 30, 2008
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
I bought a Toro ultra electric blower vac (model 51599 a year ago but never used it. Now that I need to use it I can't find what I did with the instructions. What do I have to do to attach the vacuum bag?
Common sense tells me it is not that hard you probably do not need an instruction manual, does life come with a instruction manual O Yeah the Bible. Believe in yourself review the situation, think it over you can do it!!!!!!!!!
Nov 25, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
How do i attach the leaf mulcher
I would not use any Ryobi leaf blower to vacuum and mulch up leaves. If you vacuum up a acorn or small rock, it hits the impeller, which is plastic, and knocks one of the fins off. Then you will have to have the unit repaired and they are not cheap.
HTH
Good Day.
Nov 10, 2009 | Ryobi Garden
We have a leaf blower 51587 and I don't know how to get the blower on instead of the mulcher. Thank you.
Go to the Toro site I listed below. Choose your model and it takes you to a very neat interactive manual. Basically, the blower tube goes where the bag goes. Just about the extent of it. Good Luck.
http://www.toro.com/home/customercare/interactivemanuals.html
Oct 25, 2009 | Garden
Turning the vacuum on.. paramount pb350
That blower vacuum is very easy to operate if you have all the pieces. You need the tubes to blow, you need the larger tub to vacuum and if you want also a bag to attach to the bigger tube. The bigger tube has to be attached at the opposite part of the machine and once you turn it on it will vacuum.
Apr 08, 2009 | Garden
Vacuum works, but blower doesn't
Make sure that the vacum houseing on blower is closed all the way and/or snaps shuts to engage for blowing once you have removed all vacum attachments.
Mar 16, 2009 | Toro Super Blower Vac
#51574 Toro Rake&Vac--Lost manual
You should have another door that goes in front of the impeller (blade) which doesn't have a vacuum attachment. You should first detach the vacuum door from the bottom, put on the blower tube, and install the other door that came with the blower. Hope that helps.
Nov 30, 2008 | Toro Blowers Rake and Vac - Electric...
Leaf Blowers Features
* CFM (cubic feet per minute) is the measure of vacuuming power. Ratings fall in the 350 to 600 CFM range. * MPH (miles per hour) measures blowing. Leaf blowers perform at levels from 125 - 210 mph. * Decibels (dB) is the noise rating. * Reduction ratio on mulching blower/vacuums calculates how many units of leaves the mulcher can produce. A 10:1 ratio means that 10 bags of leaves can be reduced to 1 bag of mulch. * Speed settings allow better control when blowing or vacuuming. * Attachments, such as extension tubes for cleaning gutters, are available separately.
Aug 27, 2008 | Craftsman Blower Attachment
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Electric Ultra Blower/Vac 12 Amp Logo
638 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
