Problems with charging
Hi im having problems getting my laptop to charge.im not sure if its the charger or the battery,its been fine then ive started having problems within the last week ive had to put the laptop on different angles to charge.
please help
  • 2 more comments
  • kelly_johnso Nov 21, 2008
    no the whole laptop
  • Anonymous Dec 30, 2008
    I have a Toshiba A-75 S206 laptop. The battery refuses to charge. It's a fairly new battery. I've tried replacing it and the AC adapter. No change. I also don't have the typical problem that other Toshiba laptops have with the jack. That's been repaired. Any suggestions?
  • Jam964 Feb 18, 2009
    Please help me! My computer began having the same issues, I have an Ispiron 1300. It has done this once before and I took it in to have it looked at and they said it was an issue with the inside of the computer and not the charger. Im not exactly sure what was done that fixed it because Im not the one that brought it in, all I know is that it was fixed for a long time and now has begun doing the same thing. The chargers light is on and working yet i have to hold the computer and power cord at different angles to have it stay charging. I went along like this for a couple days until one night I left it on the floor charging and Im sure that it stopped charging and by morning it had died. Now I cannot turn it on nor find an angle thats right for the light to blink. Soemtimes it blinks that its charging for a second and goes away, never stays. I dont know what to do! I am sure I will have to bring it in again, but I cant even tell if its worth it to spend money to have it fixed onyl for it to break again, or just g et a new computer. Help!
  • P. Thomas
    P. Thomas May 11, 2010
    hmm..different angles..as in the screen or the power cord?
  • 76 Answers
Ahh...ok..that helps a bit...that is most likely an issue with the place the power goes into the laptop...does the light for the battery flicker at all?
Posted on Nov 21, 2008
    Sergeant:
  • 237 Answers
This still could be either if the cord is being moved at the same time. when the laptop is able to turn on, Does everything (programs, software, etc) function properly? If yes, then we can narrow it to the battery or ac adapter.
To find out whether it is the ac adapter or battery, take out the battery, and see if the laptop powers up and stay that way. If it intermittently closes or shuts down, it's most likely the ac adapter.
If it stays powered on, even if you move it, then it's most likely a battery issue.
If you want to be sure before spending some money, go to a friend's, neighbor's or computer store with a with the same manufacturer (dell, toshiba, etc), and borrow their ac adapter to check
Hi i have a Samsung np-r40 and it dosnt charge or get any lights working, it works fine with a full battery so comp is fine but cant get it to charge or come on useing the mains ive brought a newcharger...
Something, a component, in the laptop may have fried the charger. I don't know for sure. You would have to trace the circuit with a multimeter to locate the bad power component.
Jan 12, 2013 | Computers & Internet
Problems with new laptop battery for my Acer 6920G.
You can't force the battery with a higher charge to work without damaging the computer. If the battery is a direct replacement it should work. If your original charger is not capable of charging the battery you can consider a charger replacement but I suspect the original charger you where using was bad to begin with if that is the case. You can try locating a replacement charger but you need to make sure it is rated for computer so you don't damage the power system.
Jun 20, 2010 | Acer Aspire 6920 Notebook PC
Hi There, I have a HP Pavilion ZE4900 and recently the AC plug in won't work. I have taken the battery out and put it in another comuter that is the exact same and it charges fine, I put my battery in the...
If your computer won't charge the battery, but the battery charges fine in another computer, and you are sure that the charger is good, then your problem is probably the DC power jack. If you wiggle the end of the power cord where it attaches to you laptop, and it starts charging properly, then the DC power jack is broken.
Apr 26, 2010 | HP Pavilion Ze4900 Notebook
Ive had the same problem with my laptop, one day it just stopped charging. I would put in the charger and the blue light on the side would either be very dim or not show the blue light. I had to either...
If you have multimeter then check the output voltage of the charger, if charger is not working then replace it, if charger is working then there must be a problem with mother board, try to contact some reliable repairing engineer.
Regards;
Hasan
Dec 30, 2009 | HP Pavilion dv6000z Notebook
My new acer laptop only works if pluggd in
u try one thing just shutdown laptop remove battery and charger from laptop then after push power button for 1 minute after that install battery and charger. but not start laptop and check that charging led of laptop is running if it's runnig then put in same condition for 3 to 4 hours after that start laptop using battery only after proper booting when os load attech the charger and check charging status.
Dec 27, 2009 | Acer Aspire One PC Notebook
Charging problem
If your computer runs correctly on AC power (without the battery), the power adapter is fine. So the problem may rest with your battery. If you have been using the same battery for 3-4 years, I suspect that it may not be holding the charge (end of life)
Try charging you battery and run the computer on battery alone and see how long it lasts.
Hope it helps
Sep 07, 2009 | Sony VAIO PCG-K35 Notebook
Dell Laptop Charger, wont charge bat. but keeps computer running.
Hi there.
In some cases batteries tend to not charge up because one of the cells are damaged or drained to the point that they will not charge at all.
In other cases it can be the power board on the laptop motherboard itself which can have gone faulty, the only way to tell is to obtain another battery (preferably new) and see if it will charge the new one, if it does then you know that the battery is faulty, if it doesn't then you will have to take the laptop into a shop to be looked at.
This is the only way you are going to be able to work out which one of the two is the cause.
Good luck and thanks for using FixYa!!
May 07, 2009 | Dell Vostro 1400 Notebook
Battery problem or camera problem?
A new battery should help you to solve this problem.
Aug 07, 2007 | Casio Exilim EX-Z57 Digital Camera
Computers & Internet Logo
245 people viewed this question
David Payne
David Payne
