Question about Video Game Consoles & Games
Playstation 3 60GB: all cables are connected correctly and there seems to be no damage (at least on the outside). However, after turning on the switch at the back and pressing the reset button, the red light turns green briefly, then yellow, then into a flashing red light. What's wrong??
  • 903 Answers
I have red many forums on this issue, and it appears to be a system error and the system will be replaced if you still have your warranty and proof of purchase
Some people think that it is an overheating issue and to leave it powered off for a few hours before trying again, although sadly I do believe that you are having a system error and would recommend that you contact customer service at sony.
Posted on Nov 21, 2008
Television say check signal cable . I have a scientific atlanta cable box.What do I do?
How is the TV connected to the cable box (HDMI, component video, etc.)? Make sure that the cables are securely connected and that the TV is on the correct input. Try swapping the current cables for new ones. (The HDMI cable has come loose on my entertainment system at times.) If you route HDMI cables via a sound receiver (cable box -> receiver -> TV), try a direct connection to the TV.
For my TV, I have to turn on one set-top box before I turn on the TV to get the signals to correctly synchronize. (Try turning off everything connected to the TV and then turn on the accessories first. Then turn on the TV.) For another set-top box, it needs to be turned on before the TV. (So try both options.)
Make sure that your set-top box is on and try a different TV or input if possible. If a second TV doesn't work with the box, contact the provider and check for a service outage. (Also try a different set-top box (like a blu-ray player) to check if it is the input on the TV.)
Note: I've had mice or other things damage wiring; this takes out the cable and phone lines. If this is outside damage, your service provider should repair the damage for free.
I hope this helps. Please add a comment with more information about your TV and the connections that you are using for additional support.
Apr 25, 2013 | Televison & Video
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
Why does my playstation 3 keep turning off and the red light keeps flashing?
This can can be any one of numerous issues. The first step toward setting everything to rights is to discover what the light is trying to communicate, outside of the obvious fact that your system is not working. First, disconnect everything from the unit, power cable, HDMI, component cables, controller-charging cables or anything else you may have connected.
Allow the unit to sit and cool off for a few minutes before re-attaching all the component wires. It is a good idea to begin with just the connection to the television. You can also try a manual reset of the system if the above steps do not work, simply press and hold the power button for ten seconds.
If none of the above works, you are dealing with a serious PS3 flashing red light issue. This could be a faulty power supply, dead hard drive or malfunctioning CPU just to name a few. You will need to check all these components out and determine if they are still functioning correctly. Screwdrivers and a few other common household tools may be required.
How old is your playstation?
Also try this link if you playstation is outside of waranty
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
I have a black screen when I connect the HDMI cable. When I connected it originally it worked for about 5 minutes but now I get nothing but the black screen. I tried connecting a different HDMI cable to it...
The main reason of HDMI black screen problem due to HDMI cable may damage and not proper connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damage, do borrow your friend cable and have a try. If your friend cable work fine, and the black screen error disappear. Then you can buy a brand new HDMI cable for replacement.
Tips 2: If tips 1 not working, you need to go another step deeper by reset your console. Most of the PS3 gamers not aware that Sony actually done include in the black screen troubleshooting method and other HDMI problems in the PS3 manual, you can find it under troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data in hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed to two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Ps3 40gb (not slim) freezes wen playng mag and black ops
The problem is not with your PlayStation 3, it is your connection ( if online) or the disk.
For the disk:
Wash the disk with water, no damage happens, it only cleans the outside.
For the connection:
If you have cable, then just clean the ends with a brush and insert it back inside.
If wireless, shut all connections and wireless devices down and restart the 3 minutes later.
Contact me at mohammad7597@hotmail.com
Jan 06, 2011 | Sony Playstation 3 (PS3) Console
Need a helpful hint on the replacement of a 1999 dodge intrepid's battery! I understand its under the wheel well and hard to get to, is there any other way that seems less complicated than taking the whole...
Battery Removal & Installation To Remove:
CAUTION
Make sure to connect the correct battery cables to the correct battery terminals. Reversing the battery's polarity may result in extensive damage to electrical components.
  1. Turn the ignition switch to the OFF position.
  2. Turn off all lighting and accessories.
  3. Remove or disconnect the following:
    • The negative battery cable first, and then the positive cable
    • The hardware securing the battery to the tray
    • The battery cover, if so equipped
    • The battery from the tray
To Install:
  1. Position the battery on the tray and install the cover if equipped.
  2. Clean the battery terminals and cable ends with a wire brush.
  3. Install or connect the following:
    • The battery hold down bracket and fasteners NOTE: Do not make the fastener so tight as to damage the battery.
    • Positive battery cable fist and then the negative cable
Nov 12, 2010 | 1999 Dodge Intrepid
Canrt seem to get a connection from box to the tv.all wires are in correct .have tried the hold the button untill it beeps twice an still no picture. platstation 3 3-275772-01
  1. Make sure the AV Cable is connected to the AV MULTI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the AV Cable into the yellow port for video, and into the white and red audio ports on the back of your TV.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive ON/OFF button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the Standard Resolution (or detect the current display output settings of your TV/monitor).
Jun 25, 2010 | Sony Video Game Consoles & Games
Hi cant connect my playstation to play online
Try making sure that all your cables to your Playstation are correctly connected.If it is a Playstation 3 then make sure that your HDMI cable or three way cables are hooked up.If it is a Playstation 2 make sure that your brodban cable is plugged in and that it is also plugged into the phone jack.Hope it helped
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
When i plug playstation 1 into tv and press play there is no game visible and i have no instruction manual to follow
Make sure that your cables (yellow=video, red=rightspeaker, white=leftspeaker) are connected properly (and pushed in nice and firm) and that you are on the correct TV/Video setting. If you dont get video AND you dont get sound, then either your cable or the outlet for that cable on the PS is damaged. In that case, get a new cable and try it out, if the problem persists, you have a broken Playstation.
Sep 25, 2009 | Sony Video Game Consoles & Games
Difficutly with connecting optical digital cables
Yes the digital audio cable should be inserted until there is a firm, clicking connection. It should only be able to fit in correctly with one orientation. It should be slightly difficult to remove when properly connected.
If your cable is slipping out, then I suggest you have a defective cable or (hopefully not) a damaged/defective optical connection port.
Apr 07, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
