Question about Intel D101GGC Motherboard
Intel d101ggc making buzzer sound at equal intervals and then pc hangs.
All fans are running properly and the sound is not from them.On the technical diagram of the motherboard, the component making buzzer sound is marked "SPKR". it is round in shape with a central hole and a small "+" mark on it. Can there be the possibility that the problem be from hard disk?
the motherboard is making a buzzer sound at regular equal intervals. is itindicating something? moreover the pc speed has gone slow drasticallyand it hangs frequently now. please solve my problem.
    Sergeant:
  • 207 Answers
OK this buzz is suppose to be a beep.
The device you described is called apezo electric speaker and is suppose to beep a post code to help define a problem.
If it's buzzing and not beeping there is either a fault with the piezo or the motherboard is not receiving the amount of power it needs to properly drive the speaker.
OK back to the post code. The patern is important it should be a series of long and short beeps. The fact that it is buzzing and not beeping may make it difficult to determine the difference between long and short beeeps.
Try your best to hear a pattern in it. Whether its constant beeps or 2 short 1 long or any other discernable variation please post back the number of beeps and if there is a long or short pattern.
please post back here
Thanks
Dave
Posted on Nov 21, 2008
My pc is hang many times use os windows 7 in p4
basic problem is motherboard not compatible with win 7 os,second thing check your cpu fan and lock they fixed correctly or one lock is loose
Jan 25, 2014 | Intel D101GGC Motherboard
What type of cmos batterty does an emachine t3508 take?
6/V15H 7.2V 15mAh Ni-Mh Check eBay for best prices
Mar 02, 2013 | eMachines T3508 PC Desktop
I'm looking for a diagram of this Motherboard so I can see where the ATA jumper is.
I can help you with your Intel D101GGC Motherboard problem.
The product guide pdf for your Intel D101GGC is available from intel here.
The Technical Product Specification for your Intel D101GGC is available from intel here.
Either document will specify the board layout information you are after.
I hope that helps.
Aug 29, 2010 | Intel D101GGC Motherboard
My pc is stuck
Hello
This kind of screen lock is usually caused by heat. Some component is heating up past it's tolerance. The problem is which one? Are all your fans working? There should be 1 or 2 fans in the power supply, 1 or 2 fans in the case, 1 fan directly mounted on the CPU and 1 or 2 fans for the Video chip. If all these are working then I would do one of the following: if you have the capability, put a scope on one of the cpu data lines. You should see a constant flow of data - even after another chip freezes the system. If you can't do this then just sub out the CPU. Don't forget the heat grease on the replacement CPU. If this doesn't help then you'll need a reputable repair person or check out my website: www.micromendllc.com
Sep 24, 2009 | Intel D101GGC Motherboard
**** for replacement (intel motherboard)
ask or take to where you bought from
Mar 21, 2009 | Intel D101GGC Motherboard
Upgrade
moz-screenshot-3.jpgmoz-screenshot-4.jpgIt appears that there are two PCI Express slots on the MB, 1-1X and 1-16X. You should be able to put in a PCI Express video card. If you are going to be gaming, pick out one with more memory, but be prepared. More memory equals more money.
Good luck and let me know how it works out.
Feb 20, 2009 | Intel D101GGC Motherboard
Buzzer sound from intel d101ggc motherboard
Check the fans in your pc, it sounds like at least one of them isent working properly and your pc gets overheated. When a pc going to warm it gets really slow and hangs.
My guess is that the CPU-fan dosent work properly and your CPU gets overheated, but check all the fans to be sure. The CPU fan runs cantantly, check so it dosent stop now and then.
Good luck
Nov 21, 2008 | Intel D101GGC Motherboard
Buzzer sound from motherboard spkr
Hi kuldeep11203, your Intel D101GGC board uses the Award bios. http://www.bioscentral.com/beepcodes/awardbeep.htm
Though the descriptions vary, I suggest you check your CPU heat-sink & fan assembly. Clean assembly from excessive dust build up. Remove CPU fan if possible & clean the heat-sink. Check the CPU fan, it may be turning too slowly & may need to be replaced. The average CPU fan runs between 2000 Rpm & 3000Rpm. Blow out your power supply with canned air. Disconnect & than re-connect the Main power connector (2x12) on the board. Item No# K, found on page 11 in your manual. Try these first. See if the buzz sound stops after a good cleaning.
If not replace the Heat-sink assemble with a new one. Check this link for a new assembly for LGA775 socket;
http://www.google.com/search?hl=en&q=heatsink+and+fan+for+LGA775+socket&btnG=Google+Search&aq=f&oq=heatsink+and+fan+for+
Good luck kuldeep11203!
Mike
Keyboard and mouse problem
1. You can disconnect the Hard disk then test the system if keybaord and mouse working, then there i s problem with your operating system or RAM.
2. Processor fan will rotate even after system hang up.
3. Check the RAM for cause
4. Operating may need to reinstall
May 25, 2008 | Intel D101GGC Motherboard
Problem with intel d101ggc motherboard
Hi Rohit, you're CPU should not be running that hot & that is why you're system is restarting. Very soon the CPU will burn up.
Replace the CPU's HeatSink & fan assembly as soon as possible. The link I have posted is a list of the CPU's you're board can support.
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-025906.htm
Even at 70'c, that's too hot also. You're game is not putting that kind of load on you're CPU.
May 09, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
201 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
