Question about Samsung LN-T4053H 40 in. LCD Television
Can't get picture in wide format on the menu. 16:9 and 4:3 only.
My Samsung LN-T4043H LCD TV will not let me get the picture screen in the wide format. When I use the 16:9 format the cars and people all look too wide and fat, so I have to use the 4:3 format for the objects to look the normal size and if I use the the 4:3 format, I'm not using the entire width of my TV...I may as will be using a standard TV since I can't use the wide screen. The menu has the wide format in shaded gray when I scroll down the picture menus so I can't select the wide format. Is there a way I can get the TV remote menu to highlight the wide format so I can select it? Thanks, Curt
  • Anonymous Mar 22, 2014
    Changing the Direct TV picture settings doesn't help
I had the same problem with a 50". The only way I could fix it was to set my Bose system to 4:3 format and the tv to 16:9. Now you can use the zoom to get the right size
good luck
eltjo
Posted on Jan 19, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Samsung LN-R408D 40 in. no picture
I'm willing to bet you have a backlight problem. Turn on the TV, take bright flashlight and shine it on the screen. Do you see the faint image???
Jul 28, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Expand to full screen. I don't have the manual . I can't seem to get the picture to fill the entire screen.
press menu and move to picture settings and look for format or size if will have either (auto / 16.9 / panaranic / 4.3 displayed change it to full or 16.9
if there is a button on remote with aspect / zoom or format on it press until picture fill screen
Dec 20, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
Screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
Aug 14, 2009 | Samsung LN32B360 32 in. LCD HDTV
Small picture from player (not wide screen)
Set the all settings to wide, not auto as if the player is set to 4:3 format then this sends a signal to the tv telling it so.Go into the setup menu and choose picture format set to 16:9 or wide. Set the tv to auto and this will keep all picture inputs to origional format. I.E. if it was recorded in 16:9 it will play in 16:9. You could set the tv to 16:9 but it will distort the picture on 4:3 recordings.
May 31, 2009 | Sanyo DRW-1000 DVD Recorder/VCR
Offset picture
You need to change the Display menu for picture mode to 16:9
no wide fit or scan fit.
Jan 28, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Picture Size problem with Samsung Flat panel LN-T3253H
You should contact Samsung service to know if the internal setup for the picture sizing was not adjusted properly at the factory.
Take care that some of these sets have a user zoom mode. Maybe it is in the zoom mode. Check in your instruction manual before calling for service support.
Jerry G.
Apr 12, 2008 | Samsung LN-T3253H 32 in. LCD Television
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LN-T4053H 40 in. LCD Television Logo
247 people viewed this question
Jerry Greenberg
Jerry Greenberg
