Question about Sony KP-57HW40 57" Rear Projection Television
Sony KP 57HW40 Blue screen and then shut down
You can get the TV to stay on if you keep putting it back on. Now, the TV has a green color tinge to it. Did the blue go out on it? Is this TV shot and is it better to get a new one?
  • rgofreed Mar 25, 2009
    All bulbs come on then the red a green shut off... the screen goes blue then shuts itself off and flashes the stand-by led on the front 8 times stops then 8 times then stops continuously.
  • 4,889 Answers
The tv shutting off can be explained by some kind of protection circuitry turning the set off.. This can be due to a variety of reasons most common reason being overheating.
Posted on Nov 25, 2008
Hi i have a kp-57HW40 sony projection tv. Right now it is failing, and when I turn it on I hear multiple clicks. The screen will not even light up, just stays black as it if were powered off. On the...
Thats the error for having a issue with the +5V which can be caused by either the A board or the B Board with the B board being the most likliest cause.
Jul 09, 2011 | Sony KP-57HW40 57" Rear Projection...
Have Sony Model# KP-57HW40 Big screen rear projection tv..Has blue wavy lines across screen, and sometimes flashes blue, can you give me assistance??
Blue Picture Tube , bad Video IC on Blue CRT board.Or Blue screen drive control to tube needs to be adjusted down some.
Most Likely Bad Tube!
Jul 12, 2010 | Sony KP-57HW40 57" Rear Projection...
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Power on then off
Check the settings on the screen. If they are set too high set will cut off.
Apr 08, 2009 | Sony KP-57HW40 57" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Sonykp57hw40
sounds like the blue CRT is shorted and thats what is shutting down the set.
Jun 07, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
284 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
