Question about GE GSS25LGM Side by Side Refrigerator
GE GSS25LGM Ice maker not dispensing ice
My 2001 fridge makes ice and dispenses water, but won't dispense ice - either cubes or crushed. Looks like the motor that turns the big plastic screw that runs thru the ice bucket isn't making that screw turn. Any ideas?
Thanks!
  • rolandv192 Nov 21, 2008
    Forgot to add that when the lever outside the door is pressed there is a low straining sound that comes from the freezer as if the motor was trying but was jammed...
  • rolandv192 Dec 16, 2008
    Thanks much for your advice.
    I'd done the dump, thaw and dry routine twice to no avail. I've found that I can "trick" the freezer into thinking the door is closed w/ the ice bucket removed by holding the door switch and then pushing the ice dispenser. The motor won't turn. I'm pretty comfortable that the motor is really stuck.
    So, what is the trick to get the motor unstuck? Empty and unplug is not ideal, but at least it's cold outside to save the food! Is there some other way? Would timing an attack on that motor w/ the defrost cycle help?
    Thanks much for your help!
    Scholar:
  • 111 Answers
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Posted on Dec 16, 2008
  • Expert Brian Dec 17, 2008
    You won't be able to "force it" into defrost so forget that (defrost is controlled by the motherboard). Pull the ice auger motor shelf out be removing 3 1/4" screws and unplugging it. Then run a hair dryer at the back of the motor for a while (20-30 minutes) on low heat until you can turn the stainless steel drive fork by hand (with steady, even pressure). Do NOT overheat the motor!!! Long gentle heat is the best. Then cover the motor with a small plastic bag (sandwich bag) tape up as many openings that you can get to to seal off any moisture from getting into the motor. Reinstall it and you should be good to go
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My GSH22k gre makes only dispenses crushed ice
You've got a bad solenoid. The "trick" only works sometimes.
Jan 16, 2010 | GE GSS25LGM Side by Side Refrigerator
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispensing problems
Check that the crush mechanism is not jammed with ice. That could prevent it from disengaging.
Dec 31, 2008 | GE GSS25LGM Side by Side Refrigerator
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
902 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
