Question about Quest Software SQL Navigator Professional Edition 3.2 (PRO-NAV-PK) for PC
QUEST SQL Navigator 3.2 with Oracle 10g Fails
The SQL Navigator 3.2 fails to connect to Oracle 10g. Oracle 10g is on a Windows 2003 Server. The Navigator is running on a Windows XP Pro v2002 workstation. This software is a debugger for Oracle stored procedures and scripts. The error message states: Error: 1.0.[Load interface dll's failed.0] The SQL Navigator 3.1 worked under Windows XP workstation connecting to Oracle 7 on a Windows NT 5.1 Server. Any ideas! Thanks
  • 2 more comments
  • suhailf Dec 26, 2007
    I get the same error while trying to connect to Oracle 10g:
    sql navigator error 1.0 (load interface dll's failed)
  • Anonymous Jul 25, 2008
  • Anonymous Jan 27, 2009
    Unhandled Exception at startup - Invalid filename
    Report the problem to Quest Support. Application will be terminated (some memory loss is possible) when you press OK.
  • Anonymous Feb 28, 2009
    i have SQL Navigator v 4.1 and can't connect to oracle 10g
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Posted on Sep 12, 2008
    Problem Solver:
  • 4 Answers
I'm sorry but I'm not familar with this software. I will change my posting. I know dos allot and awk.
Posted on Jun 23, 2007
In registry
Ora8 - HKLM\Software\Oracle\ALL_HOMES
Ora10 - HKLM\Software\Oracle\KEY_OraDb10g_home1
- Its the folder that points to the dll's that the Navigator uses.
copy all keys from that folder to
Posted on Aug 18, 2009
Copy ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. In my case it helped.
Posted on Feb 19, 2008
What is SQL?
It is a special purpose programing language. Computer language you will never use, unless you are into servers or programing type software
Jan 27, 2015 | Oracle 10g Database Standard (ODBSEONUPP0)
Which database can I use with ColdFusion?
ColdFusion supports ODBC-compliant databases. With Net Nation's ColdFusion plans, you can use a Microsoft FoxPro, Microsoft Access or Microsoft SQL Server database. ColdFusion supports both DSN and DSN-less connections.
Oct 09, 2014 | Oracle 10g Database Standard (ODBSEONUPP0)
I installed oracle 10g express edition.now I dono how to remove it. please let me kno how to uninstall it.I even stopped the oracle services but i dino abythin further.
Follow these steps:
  1. Open the Windows Services utility: From the Start menu, select All Programs, then Administrative Tools, and then Services.
  2. If any of the following Oracle services exist and have the status Started, then select each of the services, and click Stop:
    • OracleXE
    • OracleXETNSListener
    • OracleJobSchedulerXE
    • OracleXEClrAgent
    • OracleMTSRecoveryService
  3. Exit Services.
See also the Microsoft online help for more information on stopping services.
7.2.2 Step 2: Remove the Oracle Database XE Registry Editor Settings Follow these steps:
  1. Log on to Windows with Windows administrative privileges.
  2. Ensure that you followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop the Oracle Database XE services.
  3. Start the Registry Editor at a command prompt:
    SYSTEM_DRIVE:\> regedit
  4. Go to HKEY_CLASSES_ROOT.
  5. Delete the following keys:
    • NEED TO CONFIRM THE XE-SPECIFIC ONES.
  6. Go to HKEY_CURRENT_USER\Software.
  7. Under Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu\Programs, delete the Oracle Database 10g Express Edition key.
  8. Go to HKEY_LOCAL_MACHINE\SOFTWARE and search for the ORACLE group key.
  9. Expand the ORACLE group key and then delete the KEY_XE and OracleMTSRecoveryService keys.
  10. Go to HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI.
  11. Expand the ODBCINST.INI key and remove the Oracle in XE key.
  12. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services.
  13. Delete the following keys:
    • OracleServiceXE
    • OracleXEClrAgent
  14. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Application.
  15. Delete the Oracle.xe key.
  16. Exit the Registry Editor.
  17. Restart your computer.
7.2.3 Step 3: Update the System Variable Path Follow these steps:
  1. Open System from the Control Panel.
  2. In the System Properties dialog box, click the Advanced tab, then click the Environment Variables button.
  3. Select the system variable Path and edit the Path variable to remove the Oracle Database XE entry. For example:
    C:\oraclexe\app\oracle\product\10.2.0\server\bin;
  4. Save your changes and then exit the Control Panel.
7.2.4 Step 4: Remove Oracle Database XE from the Start Menu and Desktop Follow these steps:
  1. Select Start, then All Programs, and then Oracle Database 10g Express Edtion.
  2. Right-click Oracle Database 10g Express Edtion and from the menu, select Delete.
  3. On the desktop, right-click the Get Started with Oracle Database 10g Express Edition icon and from the menu, select Cut.
7.2.5 Step 5: Remove the Oracle Database XE Directories Follow these steps:
  1. Ensure that you have followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop all Oracle Database XE services.
  2. From the Windows Explorer, navigate to the directory where you installed Oracle Database XE, for example, c:\oraclexe.
  3. Right-click the Oracle Database XE installation directory and from the menu, select Delete.
7.2.6 Step 6: Install and Run the Windows Installer CleanUp Utility Run the Windows Installer CleanUp utility to remove the Windows Installation configuration information for the Oracle Database XE installation. You can download it from Microsoft at:
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
he deinstallation completes, click Finish.
Sep 14, 2010 | Oracle Database 10g
Whst is the difference between .mdf,.ldf & .sdf?
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
Dec 03, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
What is an sdf file and how it creates from which application.
.SDF File Extension (SQL Database File), the filef ormat for Microsoft SQL Server Compact databases.
Please rate this a fixya
Jan 30, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
Oracle 10g Error
You're using the wrong password.
Sep 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Oracle SQL Error
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
Sep 04, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Can we install Server component in Vista Home Basics
I see no reason why you cannot do so. Just make sure you find all the drivers for you laptop before you migrate.
Apr 18, 2008 | Microsoft Windows Vista Ultimate Edition
Network and sql serivices failed during startup windows 2003 server os
Check all this----------
1-check the services (stop the service & start the service from the services)
2-check the firwall setting.
3-check the n/w card
4-Remoove the unwanted s/w
5-check pc for the viruses
I think this activity help you.
Mar 07, 2008 | Microsoft Windows Server Standard 2003 for...
What is a .sdf file? How to generate a .sdf file using ms access?
Regarding what is .SDF -- A file format that is compliant with the combination of SQL Server 2005 Compact Edition, SQL Server 2005 and Visual Studio 2005 to build, test, deploy, and manage applications for users. Databases of this type can be accessed directly as a datasource, e.g., from Visual Studio 2005, or from SQL Server Management Studio. As such, they can be passed around with programs or projects, although they are mainly used for embedded applications. The file includes all necessary code points to access the data, and so does not require an instance of SQL Server to be installed.
You can create a .SDF file with a software called PocketSYNC. (Although i have never tried it myself, a lot of people claim that this software works like charm. But it is not free)
Oct 17, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Quest Software SQL Navigator Professional Edition 3.2 (PRO-NAV-PK) for PC Logo
4,626 people viewed this question
Top Quest Software Computers & Internet Experts
Alun Cox
k24674
Are you a Quest Software Computer and Internet Expert? Answer questions, earn points and help others
