Question about Kenmore 65924 Electric Dryer
Dark stains on some clothes after drying
My 7 yr. old Kenmore 80 series dryer leaves dark, unremovable stains on some clothing. Does not happen all the time but this morning I once again found damaged clothing. There is a metal vent on the back wall of the dryer that appears to have a brownish stain on it. The stain does not rub off when rubbed with a dry or damp rags. Help!
Any ideas on what the problem may be? Is it possible to remove & replace the vent?
  • arenson Nov 24, 2008
    Thanks for the suggestion. Yesterday we took the agitator out of the washer and discovered it was cover with crud on the outside and inside. We cleaned it thoroughly & decided that clothes may have rubbed against the crud which left a stain on them. If we encounter any further problems, we will give your suggestions a try. We appreciate your help.
I had this same problem. I turned out to be the seal around the drum. You have to remove the drum and put in another seal. Not real hard to do. You can order the seal from sears and I think the glue came with it. Just have to remove the lint vent screws and then the top lifts off. then remove the screws to the front panel. Hold the drum because it will fall. Unhook the belt. Remember how it connects. Then take the drum off and remove the seal and as much leftover glue and fabric. Glue the new seal on and let dry. I did overnight. It should have directions. then replace everything. just make the seal is on the same way you took it off so look at everthing before you remove anything. Once the seal was replaced no more stains.
Posted on Nov 23, 2008
My dryer is leaving rust stains on my clothes
you needto replace your dry drum .
Sep 30, 2015 | GE Dryers
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
My 80 series Kenmore Dryer is heating up, tumbling, but my clothes aren't drying. It's taking 6-7 cycles to get anything dry, I have checked the vent hose and everything. All seems to be checking out ok....
You need to check your vent, or your vent system in your dryer. You also need to check to see if your clothes are tumbling. If not then your belt could be broke. Good luck!
Aug 21, 2010 | Dryers
Hello I have a Kenmore clothes dryer (80 series). It takes multiple cycles to dry the clothes.
Remove the connecting vent on the rear and run a timed load 45 minutes. If it dries correctly repair the vent blockage.
Oct 26, 2009 | Kenmore Dryers
The machine is spotting the clothes/ It looks like dark fuzz, but its staining the whites. How do you remove the agitator???
Amazing, my washer was doing the same thing, i was getting unremovable stains on my dark clothes. to fix this problem you have to changed out the gearcase...leaking oil....
Sep 13, 2009 | Washing Machines
I have a kenmore 80 series dryer.When using the auto cycle the clothes come out damp
Kenmore Dryers are all almost the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Dryers
Kenmore Series 80 (110.74882401) heat cycles on only for 10 secs
This is a pretty easy fix and I recently had the same problem. I made a quick video about it. The problem was the dryer was run only a few mins then quit. The dryer limit was tripping because the control thermostat was not shutting down the lower safety limit was tripping and the power from the control thermostat was diverted via the orange wire to the timer motor which kinda caused the main motor to stop. When i ran the dryer in NO HEAT the dryer stayed running and that was my clue as to what may of been happening and that was the problem in a nutshell. My video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2017 | Kenmore 659 Electric Dryer
Kenmore 80 Series Washer/Dryer
I HAVE SEEN MOST MARKS COMING FROM THE DRYERS. AS THEY AGE, THE FELT AIR SEALS ON THE DRUM DETERIORATE AND THE CLOTHES GET PINCHED BETWEEN THE DRUM AND THE BULKHEAD AT THE REAR OF THE DRUM. OTHERWISE CHECK THE HOLES IN THE WASHER TUB IF YOU HAVE A PORCALIN ON STEEL TUB IN THE WASHER.
Jan 26, 2009 | Washing Machines
Dark grease stains on the cloths after drying
Most likely a bearing failure, a seal that retains grease has given up and is spewing into the drum through a shaft opening of some kind.
If you are positive there is no grease in some of the clothes, or someone is putting it in the drum, then a seal has failed, and now that the grease is coming out, the bearing it is was supposed to lubricate is now low, and will fail prematurely, you need a service call and soon.
Will
Nov 17, 2008 | Dryers
Kenmore 65924 Electric Dryer Logo
193 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
