Question about Intermatic & Indoor/Outdoor Rain Tight Timer
How to program Intermatic model T101-70
Need instructions on how to program the timer for christmas light display. Do not want to hook to computer - only want to set lights in a timed sequence.
  • 1 more comment
  • Anonymous Dec 02, 2008
    I also need help. The instructions are in french.
  • Anonymous Apr 30, 2009
    the clock wont run
  • Angela Defranco
    Angela Defranco Aug 16, 2012
    The timing mechanism runs but it wont turn off the lights.
  • 44 Answers
Do you have the screw on trip pieces? They look like little arrows with a thumb screw on them. Some of them should say On, some Off Place the on trips over the time you want the lights to com on vice versa for off. To set the time pull out on the yellow time wheel and rotate until the arrow that is pointing down is over the current time. I hope this helps.
Posted on Dec 04, 2008
I have a HB88RC Intermatic 7 day / 7 event timer. I have followed the "easy set instructions" I have program 1 set to turn on X-mas lights at 4:30 PM and go off at 11:30 PM. For all seven...
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
Need a copy of manual
You can get the manual on the link below.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et8215c%20-%20english.ashx
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 25, 2010 | Intermatic ET8215C- 7-Day Electronic...
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
My son lost the instruction manual for our DT 500 CH self-adjusting timer made by INTERMATIC INCORPORATED, and we can't even figure out how to turn it on, let alone program it. Any help would be great!...
I Just downloaded the pdf for the same model. The link to Intermatic is http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt500ch.ashx
If that doesn't work then google Intermatic DT500CH pdf and select the return from Intermatic. It's a good timer but not intuitive. I had to look up the manual just to change from daylight savings time.
Dec 24, 2009 | RTO Intermatic DT500CL 10 Amp Indoor...
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk unless you set override feature shown below
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
Need instructions
I have a similar sounding timer. It has the same dial and an AM/PM window on it and is made by Dynascan. I found this post on Fixya: http://www.fixya.com/support/t2314418-instructions_program_intermatic_ej351c and then went to the intermatic site and got these instructions: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx I used the RAPID programming instructions and they seemed to work great (at least the red light acted like it was supposed to.) Guess I'll find out tonight :)
Dec 01, 2008 | Hardware & Accessories
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
1,596 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
