4100 Grinding Noise
So is a drum drive gear something I can fix? Where can this part be ordered? Is there someone I can call to have them come and fix it?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
It is fixable,
The gear is the one that is inside on the bottom usually left side. Look at your drum see which side has gears and and simulate how it goes in, you will see which one it aligns with.
Is there residue next to it? do the teeth look rounded instead of sharp?
Now that you have located it you can get a feel of the scope of work involved, if a tech or very handy w/electro-mechanical stuff you ca do it. (scale 1-10 this is a 10)
You will need to look for a fax service repair shop, try going w/a local mom and pop instead of the big guys they are expensive ($120 just for labor !!!) a mom and pop usually start at 75
try to see what the price of the part will caost and you can determine if you just need to get another fax!!!
Try these sites for references on $$$
brokenfax.com
precisionroller.com
also google fax repairs for your area
Posted on Nov 21, 2008
Defy Laundromaid 1300 making grinding noise while washing,how do i remove pulsator to see if there is something in it
if the grinding noise is more pronounced at spin cycle , it could be the drum it self, if the grinding noise is there constantly, could be the bearing to the drum. front loader. easy to fix, let me know..
Apr 14, 2014 | Washing Machines
Horrible noise
do u have fixed properly drum unit do u have tested with the older drum is the same i think you dont have fixed proply thats ywhy u getting noise from gears just try to fix proper thanks
May 12, 2010 | Brother IntelliFAX 4100 Laser Fax
Grinding noise at startup paper jam indication (alarm flashes 3 times) no paper stuck in printer sounds like plastic gear is not meshing grinding sound occurs twice during powerup
definitely sounds like the drive gears are stripped, did it jam and someone pull paper out by hand this is major cause of stripped gears. generally fixing is not cost effective cheaper to buy new
Jul 07, 2009 | Office Equipment & Supplies
Makes a grinding noise near the drum. Copier works, but makes a "gear-grinding" noise near the drum area. Can't tell what's doing it.
Un load the drum unit, check the drum/s gear, is it wear off, if so change it along with the drum's drive gear at machine base, check also the gears of developing unit
Jun 29, 2009 | Sharp AL-1540CS All-In-One Laser Printer
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Recieving fax error
It could be a bad drum unit. If the drum doesnt turn smoothly it will make a clicking or grinding noise since it is gear driven. Take out the drum and turn the gear with your thumb. turm towards you. If difficult Thats it. It also could be a fuser gear. good luck Lawrence
Apr 22, 2008 | Brother IntelliFax-2820 Laser Fax
Gear making a grinding noise
Not too good news I'm afraid. It sound like the fuser gear has failed. Generally the fuser unit (hot section or hot rollers in the back) need to be replaced. Usually when the gear has worn or failed the fuser rollers are also worn and need to be replaced. The gear can be replaced seperately but is a very risky operation and usually results in parts in the fuser unit falling appart due to age and wear, so it is best done as a unit. If possible do not run the machine as it can cause damage to gears around the fuser unit. The best option is to find out how much a fuser unit and labour to fit would be at your local service centre.
Jan 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
87 people viewed this question
k24674
jasbo
jasbo
