Question about Lands Phones
Kx-tga301cs cordless phone panasonic. I have a dial tone and when i press on a number the touch tone is heard but the dial tone does not change so i can not call.
SOURCE: panasonic cordless phone #KX-TGA931T
For the speakerphone switching phone off problem, substitute the 630 mAh Ni-MH battery that comes with the phone with a better Ni-Mh battery of higher mAh such as Duracell or better yet eneloop.
Posted on Apr 18, 2009
SOURCE: Panasonic KX-TGA601CB cordless phone Was working
phone says move closer to base
Posted on Jan 28, 2010
SOURCE: Panasonic phone KX-TGA710CX - Analog/Digital dialing
what is the recommended battery put in the panasonic kx-tga710cx?can i put ordinary battery or rechargeable battery?
Posted on Feb 07, 2010
Sijju
SOURCE: TO CHANGE PULSE MODE TO TONE MODE- INSTRUCTIONS ON
-Press "Program button"
-Press "AUTO" buttton (Just left to the "TALK ON/OFF")
-Press "*" two times
-Press "Program"
Along BEEP sound will come. That's all..!!
Posted on Feb 16, 2010
  • 25 Answers
SOURCE: how do i change from tone to pulse on panasonic
Try this.....Press menu....enter (# 1 2 0). Now select up or down key to get tone or pulse. Then select Save then off.
Posted on Nov 10, 2010
Touch tones don't work a bank login
We recommend you use change the handset's dialing mode from pulse to tone.
Apr 11, 2014 | Panasonic KX TGA641 Cordless Phone
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/KXTG5664.PDF . See page 17 for setting the Dialing mode.
I hope this helps.
Apr 06, 2013 | Panasonic Lands Phones
Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
Nov 30, 2009 | Panasonic KX-TG2352 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
How do I set 1 touch dialing?
It's pretty much phone system dependent on the one touch, but PROG F button, 9+number STORE usually works.
As far as the calling into IVR systems, you may have to press # to send touch tones after you dial a number, or adjust the tone length in programming. Of course not all systems let you change DTMF times, but that's another thread :-)
Carl
Jul 02, 2008 | Panasonic KX-T7731 Corded Phone
Lands Phones Logo
354 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
