Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Won't boot; now no video
Purchased a custom built computer over a year ago and it worked fine up until I turned it off last night. But, when I turned it on this morning it would not boot. It halted at screen saying to press DEL for setup. It wouldn't go to setup. After trying several times, I unplugged everything, removed the battery and moved the reset jumper for 10 secs. per manual instructions and returned it to normal state. Now, I don't even get video. The lithium battery CR2032 has 3+ volts. Any clue as to what happened?
  • rwbta Dec 10, 2008
    Thanks, but the problem turned out to be dirty connections on the memory chips.
    President:
  • 2,351 Answers
Hi rwbta, from your description it sounds like a bios issue.
The bios only displays: (Press the Delete key for setup) when there is a problem with a device.
(Hard disk drive, video device, over clocking settings, ECT). After resetting the bios (As you have done), display should resume. Since it did not suggest you plug the monitor into the second VGA or DVI port on the graphics card & check for display. Try another monitor, (Just to be sure). If you are running in SLI, disconnect the primary PCI express card (Blue slot) & replace it with the second PCI express card. Boot the system & check for display. No display? Move to the second port on the card & check for display. Still no display? Than it is possible your bios may be corrupt.
You can buy a new updated bios directly from Asus estore online, click this link;
http://estore.asus.com/shop/ There are currently 217 pages to search through in order to find the bios chip for the M2N-E SLI board. (Your board is still under warranty).
You can save time by calling Asus tech at; 1-812-282-2787 & talk with a tech. If you choose to do so please write down the S/N found on the parallel port. The tech will want this & check to see if the board is still in warranty. After a short talk with the tech he or she may include another suggestion or you can just ask for an updated bios chip. In either case be sure to get a case number. The average cost for a bios chip is $5.00 not including shipping. Since this board is still in warranty this item should be free for you. Asus store hours: Monday - Friday 8:00 AM. To 6:00 PM PST, excluding weekends and / or holidays.
Good luck rwbta!
Mike
Posted on Nov 22, 2008
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Windows 2000 xp will not boot up
Quite possibly your hard drive is either bad or going bad. I hope you have a backup of your stuff.
Oct 01, 2017 | Pioneer Computers & Internet
I have an Asus Striker Extreme III motherboard running a q6600 with 4gb of patriot 1066 ram and an asus 8800 gtx video card. My computer has run fine for the last 3 years and had been working fine. Then a...
This sounds like the power supply - before buying a new motherboard can you get voltages from the pin connectors that power the board? You can use a simple multi-meter - set to 12V and register the current.
May 01, 2017 | ASUS Striker Extreme Motherboard
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have an HPa6700y I purchased about three months ago.  At the time of purchase I installed a high-end graphics card myself (ASUS EAH4870 DK/1G Radeon HD) and it had been running beautifully until...
usually there are 2 problems: 1. a vga card overheat when running 3 games the vga card heats up. try using an case fan or adn a vga fan. 2. the game uses a high refresh rate in this case tri to set a default refresh rate from the vga driver. hope this helps
Jun 14, 2009 | Computers & Internet
Bios says no ide device found (hard frive missing?)
If the BIOS is not detecting your hard drive, then there are two possible suspects here. Could just be your hard drive or it also be your motherboard.
If you have already reseated your hard drive and memory and the symptoms are still the same, then go to the nearest local computer shop that sells HP. Have them try a known-good hard drive on your system. If it works, purchase a new hard drive. If it doesn't work, your mobo needs to be replaced.
Jan 01, 2009 | HP Compaq Presario v3000z Notebook
I have a canon sx100is digital camera i purchased a week and a half ago. it was working fine until last night when all of the sudden the lcd went black. it still works, the camera just will not take new...
Turn on the camera and press the DISP button once. Take the camera back for exchange with your retailer if this does not correct the problem.
Jul 03, 2008 | Cameras
Mach speed
Unplug the the dsl & any other device except the keyboard & mouse. Double check the video cable at both ends monitor & PC. Boot up system. If the system starts shut down & connect 1 device. Boot the system. OK? continue to do this. On the dsl there is a reset button. With it unpluged from power use a pen & hold in the reset for about ten seconds. Reconnect the power & reconnect the Rj45 to the PC. Boot system.
Jan 26, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
185 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
