Question about Cavs CDO-98E
Power shuts off
My unit is Hyundai 98+, and the problem is its power automatically shuts off after 20 minutes of use
0 characters
1 Points
My Philips model DVD750R/17 shuts off when playing a VCR tape after about 15 minutes. Why?
The most likely cause is a problem with the mechanism that moves the tape(when played a bit more weight is on the takeup reel.
Someone would have to open the unit so they can see the reels moving---watch to see if it begins to hesitate when further into the tape.
A trick that can help to see is put a fully rewound tape in and hit fast forward--let it go all the way to the end and rewind--if unit does not stop after doing that see what happens in play.
A worn drive unit that moves the tape can sometimes get better after run this way.
Dec 06, 2012 | DVD & Blu-Ray Players
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
Unit is always shutting down / turning off
Try first unplugging power cable for five minutes and using a different power outlet, if you still get the problem, the unit has a faulty power supply on the board inside.
Nov 12, 2008 | Pioneer DVD & Blu-Ray Players
Power button flashes SAFE
I unplugged the unit for 30 minutes and it finally went out of safe mode.
Oct 12, 2008 | DVD & Blu-Ray Players
Upgrade my hyundai 98-pro edition karaoke player
I have a problem with my Hyundai 98premier. Iconnot play my DVD with MTV in my unit. hOW CAN iUPGRADE MY unit so that I can play and hear my MTV. thankyou and god guide you always.
truly yours
Douglas S. Duran
May 18, 2008 | DVD & Blu-Ray Players
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
May 06, 2008 | DVD & Blu-Ray Players
The power shuts off after a few minutes
There could be several factors. Are there any indication or failure lights/codes prior to the unit shutting down? You didn't mention where the unit is located. Does it initially start to read the disc then shut down or is there no activity at all? Please respond with some additional info & we'll go from there.
Feb 21, 2008 | DVD & Blu-Ray Players
My LG DN191H DVD player keeps shutting itself off every 5-10 minutes while I'm watching movies. Every time it shuts down I have to power it up and go through all of the menus again. It's really irritating....
laser problem just trash it. I got one that have the problem 2 months after purchase and was sent back to manufacturer after another 3 months I'm getting disc error. I guess they have a problem on the laser reading assy
Sep 02, 2007 | LG DN191H DVD Player
Won't ower up
Unplug unit for about 20 minutes then plug back in and see if it works
Aug 27, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cavs CDO-98E Logo
15 people viewed this question
Top Cavs DVD & Blu-Ray Players Experts
Are you a Cavs DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
