Hello, I'm having the Error code C0400 when attempting to use Minolta 3050. Can you help?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
In minolta this error is for exposure lamp .just check ur exposure lamp.may bi it is dead or supply problem .by mian jee
Posted on Dec 17, 2008
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Malfunction Code C0400
You might try Googling the copier name, model number and/or any error code message you receive.
Nov 11, 2013 | Konica Minolta Office Equipment & Supplies
Whats the problem if code C04 come from Minolta EP1083
The error code is displayed in 2 section on the display on the zoom dosplay and the number display.
C0400 Exposure lamp malfunction.
C0410 Exposure lamp thermistor malfunction.
Verify the exposure lamp continuity and the thermistor continuity.To reset error code open the copier and press the reset microswitch located on the rear PWB panel ,close the machine front door.
Jun 02, 2013 | Office Equipment & Supplies
Minolta ep4000 error code c0400
C0400 -Exposure lamp failure to turn ON
C0410 -Exposure lamp turning on at abnormal timing
Turn OFF the copier,remove the glass,Work a screwdriver trough the hole in the frame at the left front side of the copier and remove the screw that secures the scanner unit.Move the scanner to rhe right hand side of the copier.Remove 3 screws to free the scanner.(To remove the scanner turn it counterclockwise).Remove 1 screw and the wire guide,remove 1 screw and the ground wire.Unplug the exposure lamp terminal connector,unplug the thermal fuse connector.Remove the scanner from the copier.Verify the continuity of the exposure lamp and thermal fuser.If is defective change.
Jan 02, 2013 | Minolta EP4000/5000 CS/PRO Copier
What is a code C0400?
Open the front door to your left upper, remove the access cover and press the trouble reset button the code you have is for the very bright light that comes on under the big glass when each copy is made. if the code comes back replace the exposure lamp and board. try web site below for a start,
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 04, 2012 | Minolta Office Equipment & Supplies
My konica minolta ep1050 is displaying error code c04 can you help me how to fix it
this is not the correct error code konicsa has 4 digits is it a c0400 if so it ids the home poition sensor for the scanner clean the sensor blow it out and see if that gets rid of your error code
Jan 31, 2011 | Konica Minolta Office Equipment & Supplies
Error code 040
I think you will find this is error code c0400 this issue if the code i am giving you is correct is a fault with the exposure lamp you can test the lamp for cont using a digital meter if the lamp turns out to be ok there is a fault with the ae sensor board on pwb-h you would need to replace this board
Jan 22, 2011 | Minolta EP4000/5000 CS/PRO Copier
Code C0400 contact rep at certain phone #...# out of service.
c0400 is exhaust fan code. Open the front door to clear. Make also all covers are closed front and both sides.
Jul 02, 2009 | Minolta EP4000/5000 CS/PRO Copier
Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
May 11, 2009 | Konica Minolta Office Equipment & Supplies
Minolta cf910
Hello sir; Press "trouble reset switch" ,open front door you will find that switch.
Jun 30, 2008 | Konica Minolta DiALTA CF910 Copier
115 people viewed this question
jasbo
jasbo
