Question about Frigidaire ATF6000ES Front Load Washer
Very loud noise as drum is spinning
The motor seems to be fine. The noise is a loud clunk as it hits certain points in the spinning cycle....almost like something has come off of a track???
  • 903 Answers
Hi, I think that the bearings may be wearing down and need to be replaced. Or the belt may be faulty and needs replacing.
To tell if the bearings are wearing down or need replacing, turn the drum by hand when it is empty and it will make like a grinding noise.
If the belt is torn, frayed or coming off the motor you will need to physically look.
Posted on Nov 21, 2008
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Aug 21, 2016 | Washing Machines
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
My washing machine makes a cluck sound at the end
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty.
If that is the case, it is normal and no need to worry about it. However, it you did not have the noise before, then best to get it checked out by a repairer.
Regards
Ash
Nov 07, 2009 | Washing Machines
Drum in Frigidaire GLTF1240AS0 has loud clunking noise
The rear drum support must be replaced.The supporting ball has eaten into the support cup.The belt will have stretched and must be replaced also. You can do the job yourself.
Aug 18, 2009 | Frigidaire GLTR1670A Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
338 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
